Results 31 to 45 of 72
Thread: 1.9.2.7-6c-pre5 available for testing
    Jun 2004
    Germany / NRW
    In what directory is the configuration file saved from the snmp server.
    Hey, my first post here... just to let you know i flashed my belkin 7230 (hw version 1222dt with 4MB Flash/16 MB RAM and mini-PCI WL nic) with the latest 1.9.2.7.6c-pre5 fw and everything works fine. Coming from stock belkin firmware, this one's really great !
    I'm experiencing some dropouts on the wireless lan part, still investigating on that, maybe the tx power settings or something. Also, I have to execute ntp manually after reboot to update date & time.
    Greetz !
    ssh not working
    i can log in to my router using telnet and whenever i try to start dropbear (normal or background mode), i try to connect to my router using putty but it still says connection refused. also when i list the current running processes, dropbear isnt present
    please help me on this one, thanks
    Apr 2004
    Netherlands
    Quote Originally Posted by nerodark
    i can log in to my router using telnet and whenever i try to start dropbear (normal or background mode), i try to connect to my router using putty but it still says connection refused. also when i list the current running processes, dropbear isnt present.
    Have you used the search on 'dropbear'?
    http://wl500g.info/showthread.php?t=...ghlight=search
    DDNS update works properly now
    Hi Oleg,
    Just updated the wl500g router with your new firmware. Checking the logfiles I see the DDNS update now works properly (this is not mentioned in your list with fixes).
    Thanks!
    Gersh
    I have encountered no major problems with 6c-pre5 so far. Only one very minor "bug" ... I set Timezone to
    (GMT+01:00) Germany
    and in status page it then says
    Fri, 28 Oct 2005 11:25:06 +0200 ... where 11:25 is exactly my local time
    While the asus 1.9.5.0 firmware would tell me
    Fri, 28 Oct 2005 10:25:06 +0100 ... what is more correct it seems (10:25+1hour is my local time again)
    Used same ntp server in both tests (ptbtime1.ptb.de).
    As I said, minor issue, but I wanted to mention it.
    ASUS firmware does not handle CET timezone properly.
    Hello.
    When your time changed from GMT+2 (DST) to GMT+1. I live in Czech republic and the time is changing on Sunday 30.10. from 3 to 2 hour. I think this is same in whole EU.
    Think I understood now, thx. So I have no bugs to report ^^ ... thx Oleg for your work. Keep it up.
    webcam features
    Is it possible to resolve problems with motion detection function on several webcams in a next version ? And include 640x480 definition ?
    Thanks for your job.
    Oct 2004
    Portugal
    testing now, and it seems to work well
    Home Page
    Marco Sousa from PORTUGAL
    Quote Originally Posted by Zitev
    Hi Oleg!
    Thank You for Your new firmware release. I'd try this, and I think it's correct. Some idea: I'm a hungarian user, and I need the 852/2 codepage for the Samba, because the long filenames is wrong on my pendrive (and the Hungarian Time Zone is too (time.kfki.hu).
    What You thinking from this?
    Sorry From My Wrong English, and Thank You For Your Help!
    Best Regards:
    zitev from Hungary
    Hi Oleg,
    I'm a Hungarian too.. and I need support hungarian characters with Samba (CP852/CP1250). Can U help us? Many thanks!
    Br,
    Amper
    Quote Originally Posted by Amper
    Hi Oleg,
    Br,
    Amper
    Szia!
    A firmware tartalmazza a 852-es kódlapot, csak azt kell default-nak választani (megszenvedtem vele, de itt a működő beállítás):
    nvram set usb_vfat_options=codepage=852,iocharset=cp852
    nvram set usb_smbcpage_x=852
    nvram set usb_smbcset_x=852
    nvram commit
    Üdv:
    zitev
    Styno: This international forum uses English for communicating with each other, please comply next time!
    Oct 2004
    Portugal
    Szia!
    nvram commit
    Üdv:
    zitev
    english, please..
    Home Page
    Quote Originally Posted by int
    english, please..
    Sorry...
    "A firmware tartalmazza a 852-es kódlapot, csak azt kell default-nak választani (megszenvedtem vele, de itt a működő beállítás):"
    - The firmware is contain the 852 codepage, just set this to default. This is the correct configuration for hungarians:
    nvram commit"
    zitev
  1. 1.8.1.7-1 custom firmware available for testing
    By Oleg in forum WL-500g Custom Development
    Last Post: 13-12-2004, 14:55
  2. Testing required for USB printers
    Last Post: 02-05-2004, 17:53
