Results 1 to 2 of 2
Thread: 84 mW firmware
  1. 84 mW firmware
    title says it all. modified the firmware to always output 84 mW.
    You might need extra cooling for this.. I've heard about overheated accesspoints.
    http://server.zomeronline.net/wl300g/
    This firmware was also uploaded to chupa.nl server - it's here
    Personally I do not recommend using 84 mW output if you don't really need this and know that you're doing. Extra signal power gives sometimes negative effects. Also you will probably need to use other antenna to radiate this power.
