upload with which protocol ? ftp, http, irc, p2p, ... ?
Hi, I am quite new to this forum, indeed this is my first post .
I have a little problem with My Asus WL500g.deluxe router.
Well, I am using it to connect 3 PCs to internet. Everythings seems to run ok, but when I am trying to upload some pictures, or mp3 or some other file, it just wont upload anything. It is really strange, becouse upload worked before I bought this router.
Has anyone any hints or tips?
Thanks
none of them work, I cannot upload even via httpOriginally Posted by ATH
have you enable lan-to-wan filter ?
No.Originally Posted by ATH
I am quite a lame and don't really understand what do I have to enable and what to disable.
retry without the router please
and reset router to defaults
without router, everything works perfectly. reseting the router didn't help. It looks like I cannot send big packets, or something like this.Originally Posted by Antiloop
could upgrading a firmware help?
Perhaps there's something wrong with the MTU size? See if it helps if you lower the MTU through the webinterface...
Do you have a problem with your Asus? -> UTFS
Newisys NA-1400 NAS info (4x hotswap SATA, 2x gigabit ethernet, 2x USB 2.0)
when I go to IP config, then Lan & Wan, I can see those options, like MTU, MRU. but those fields are gray, and I cannot edit them.Originally Posted by Styno
Hi,Originally Posted by enemista
I had the same, the solution is here:
http://www.wl500g.info/showthread.ph...&highlight=mtu
