Results 1 to 13 of 13
Thread: [RESOLVED] Can't Mount Box.com using Entware davfs2 (Asus RT-N16)
    Jun 2015
    Longmont, CO
    Question [RESOLVED] Can't Mount Box.com using Entware davfs2 (Asus RT-N16)
    I hope this is the correct place to post this. If this isn't, please let me know.
    I am using dd-wrt mega on an ASUS RT-N16 and am attempting to mount my box.com account using davfs2 loaded from Entware.
    I referenced the following sites to try to make this work:
    I successfully installed Entware and the davfs2 package, mounted another partition to /mnt, then created a subdirectory "box", then attempted to mount using the following command:
    $mount -t davfs https://www.box.com/dav /mnt/box
    Didn't work. No messages at all. Realized the link may be old (after reading the Box FAQ link shown above) and tried:
    $mount -t davfs https://dav.box.com/dav /mnt/box
    Still didn't work. Checked my log file at /var/log/messages (I had already enabled logging when setting up the router), no messages.
    I tried installing wdfs, just in case, but that didn't change anything. Same thing for installing busybox and mount-utils.
    I could use some help, even if it's troubleshooting steps. Since I have no messages I don't know what next steps to take to resolve this.
    Thank you!
    IMHO, dd-wrt is most weird firmware I ever seen. Try:
    unset LD_LIBRARY_PATH
    insmod fuse
    Before mounting WebDAV shares.
    Jun 2015
    Longmont, CO
    Still no messages
    Thank you for the quick replay and help. I tried the steps you provided and still received no messages. I've posted the output from my SSH session below.
    root@DD-WRT:~# unset LD_LIBRARY_PATH
    root@DD-WRT:~# insmod fuse
    root@DD-WRT:~# mount -t davfs https://dav.box.com/dav /mnt/box
    root@DD-WRT:~# df
    Filesystem           1K-blocks      Used Available Use% Mounted on
    /dev/root                 5760      5760         0 100% /
    /dev/discs/disc0/part1
                           1032088     14292    965368   1% /opt
    /dev/discs/disc0/part2
                          13991856     34712  13246388   0% /mnt
    root@DD-WRT:~#
    Any other steps I can try or any other information I can get to help troubleshoot? Would you recommend I switch to a different firmware? Go back to AsusWRT? Tomato? If Tomato, do you have a build you would recommend? (Toastman? Shibby? Viktec?)
    Thank you again for your help!
    Please, try to call davfs2 binary directly:
    mount.davfs https://dav.box.com/dav /mnt/box
    Jun 2015
    Longmont, CO
    Ok, that gave me an error message, which is a step forward!
    root@DD-WRT:~# mount.davfs https://dav.box.com/dav /mnt/box
    mount.davfs: can't resolve symbol 'canonicalize_file_name' in lib 'mount.davfs'.
    root@DD-WRT:~#
    I didn't get any error messages when I installed davfs2, so I'm assuming that went well. I hadn't installed anything other than what comes in the base Entware_install.sh script, so I hope there aren't any conflicts.
    This is a fresh install, so if I need to start from scratch it won't cost me that much time investment.
    Looks like LD_LIBRARY_PATH is still set. Please, provide here an output of following commands:
    ldd /opt/sbin/mount.davfs
    echo $LD_LIBRARY_PATH
    Jun 2015
    Longmont, CO
    Progress!
    Oh! I'm sorry, I had to shutdown the router and go to work between the two sets of instructions you provided.
    Here is the output you just requested:
    root@DD-WRT:~# ldd /opt/sbin/mount.davfs
    -sh: ldd: not found
    root@DD-WRT:~# opkg install ldd
    Installing ldd (0.9.32-1) to root...
    Downloading http://entware.wl500g.info/binaries/...1_mipselsf.ipk.
    Configuring ldd.
    ldd: LD_LIBRARY_PATH not included in search path: it needs ld.so stand-alone execution enabled
            libcrypto.so.1.0.0 => /opt/lib/libcrypto.so.1.0.0 (0x2aac0000)
            libssl.so.1.0.0 => /opt/lib/libssl.so.1.0.0 (0x2ac3d000)
            libneon.so.27 => /opt/lib/libneon.so.27 (0x2ac9f000)
            libz.so.1 => /opt/lib/libz.so.1 (0x2acd4000)
            libexpat.so.1 => /opt/lib/libexpat.so.1 (0x2acf8000)
            libc.so.0 => /opt/lib/libc.so.0 (0x2ad32000)
            libdl.so.0 => /opt/lib/libdl.so.0 (0x2ade4000)
            ld-uClibc.so.0 => /opt/lib/ld-uClibc.so.0 (0x2aaa8000)
    root@DD-WRT:~# echo $LD_LIBRARY_PATH
    /lib:/usr/lib:/jffs/lib:/jffs/usr/lib:/jffs/usr/local/lib:/mmc/lib:/mmc/usr/lib:/opt/lib:/opt/usr/lib
    But, given I had rebooted to go to work, I tried the following:
    mount.davfs: can't access file /etc/mtab: No such file or directory
    Shouldn't that be looking for /etc/fstab?
    Quote Originally Posted by dougletl View Post
    It requires /etc/mtab. I'm surprised it's not present in DD-WRT, you can create it by:
    ln -s /proc/mounts /etc/mtab
    Jun 2015
    Longmont, CO
    Gave that a try and it didn't work:
    root@DD-WRT:~# cat /proc/mounts
    rootfs / rootfs rw 0 0
    /dev/root / squashfs ro 0 0
    none /dev devfs rw 0 0
    proc /proc proc rw 0 0
    ramfs /tmp ramfs rw 0 0
    sysfs /sys sysfs rw 0 0
    devpts /dev/pts devpts rw 0 0
    devpts /proc/bus/usb usbfs rw 0 0
    /dev/discs/disc0/part2 /mnt ext2 rw 0 0
    /dev/discs/disc0/part1 /opt ext2 rw 0 0
    root@DD-WRT:~# ln -s /proc/mounts /etc/mtab
    root@DD-WRT:~# cat /etc/mtab
    root@DD-WRT:~#
    But I did some searching and found there should have been a fix already in place: http://svn.dd-wrt.com/ticket/1388
    So I checked what firmware I'm using: DD-WRT v24-sp2 (08/07/10) mega (SVN revision 14896)
    So that's a Noob mistake. I'm going to take some time to upgrade to more current firmware and give this another try. I will let you know if I run into more issues and will post the resolution if it works.
    Jun 2015
    Longmont, CO
    No Change
    No change on newer firmware. I'm now on DD-WRT v3.0-r27413 (06/22/15) mega and successfully installed Entware using the instructions on the GitHub site, successfully installed davfs2, but there is no link between /etc/mtab and /proc/mounts. I also still can not create one. Here is the full process in case I am missing something:
    root@DD-WRT:~# wget -O - http://entware.wl500g.info/binaries/mipselsf/installer/entware_install.sh | sh
    Connecting to entware.wl500g.info (81.4.122.163:80)
    -                    100% |***************************************************************************************************|  1143   0:00:00 ETA
    Info: Checking for prerequisites and creating folders...
    Info: Opkg package manager deployment...
    opkg                 100% |***************************************************************************************************|   476k  0:00:00 ETA
    opkg.conf            100% |***************************************************************************************************|   106   0:00:00 ETA
    Info: Basic packages installation...
    Downloading http://entware.wl500g.info/binaries/mipselsf/Packages.gz.
    Updated list of available packages in /opt/var/opkg-lists/openwrt.
    Installing uclibc-opt (0.9.32-5) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/uclibc-opt_0.9.32-5_mipselsf.ipk.
    Installing libc (0.9.32-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libc_0.9.32-1_mipselsf.ipk.
    Installing libgcc (4.6.4-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libgcc_4.6.4-1_mipselsf.ipk.
    Installing libstdcpp (4.6.4-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libstdcpp_4.6.4-1_mipselsf.ipk.
    Installing libpthread (0.9.32-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libpthread_0.9.32-1_mipselsf.ipk.
    Installing librt (0.9.32-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/librt_0.9.32-1_mipselsf.ipk.
    Installing ldconfig (0.9.32-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/ldconfig_0.9.32-1_mipselsf.ipk.
    Installing findutils (4.5.14-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/findutils_4.5.14-1_mipselsf.ipk.
    Configuring ldconfig.
    Configuring libgcc.
    Configuring libc.
    Configuring libpthread.
    Configuring libstdcpp.
    Configuring librt.
    Configuring findutils.
    Configuring uclibc-opt.
    Updating /opt/etc/ld.so.cache... done.
    Info: Cleanup...
    Info: Congratulations!
    Info: If there are no errors above then Entware successfully initialized.
    Info: Found a Bug? Please report at https://github.com/Entware/entware/issues
    root@DD-WRT:~# opkg install davfs2
    Installing davfs2 (1.5.2-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/davfs2_1.5.2-1_mipselsf.ipk.
    Installing libneon (0.30.0-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libneon_0.30.0-1_mipselsf.ipk.
    Installing libopenssl (1.0.2a-0) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libopenssl_1.0.2a-0_mipselsf.ipk.
    Installing zlib (1.2.8-1) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/zlib_1.2.8-1_mipselsf.ipk.
    Installing libexpat (2.1.0-3) to root...
    Downloading http://entware.wl500g.info/binaries/mipselsf/libexpat_2.1.0-3_mipselsf.ipk.
    Configuring zlib.
    Configuring libopenssl.
    Configuring libexpat.
    Configuring libneon.
    Configuring davfs2.
    root@DD-WRT:~# cd /mnt
    root@DD-WRT:/tmp/mnt# mkdir box
    root@DD-WRT:/tmp/mnt# chmod +rw ./box
    root@DD-WRT:/tmp/mnt# ls -l
    drwxr-xr-x    2 root     root          4096 Jun 25 19:41 box
    drwx------    2 root     root         16384 Jun 25 19:31 lost+found
    root@DD-WRT:/tmp/mnt# chmod a+rw ./box
    drwxrwxrwx    2 root     root          4096 Jun 25 19:41 box
    root@DD-WRT:/tmp/mnt# mount -t davfs https://dav.box.com/dav /mnt/box
    root@DD-WRT:/tmp/mnt# cat /etc/mtab
    root@DD-WRT:/tmp/mnt# ln -s /proc/mounts /etc/mtab
    Thank you again for all of your help, it is very much appreciated!
    Looks like nothing more I can do about that. DD-WRT has no /etc/mtab — an ordinary system file, which present on all linux systems I ever seen. That's really strange.
    Jun 2015
    Longmont, CO
    Good news! I installed the Toastman mod of Tomato (Tomato Firmware v1.28.7507 MIPSR2Toastman-RT K26 USB VLAN-VPN-NOCAT to be specific) and everything worked great!
    The only issue I'm working on now is auto-mounting on boot. I created my secrets file and created an init script to mount it, but it isn't working. I suspect it's because of the certificate issues I see when use the same command at the command line as shown below.
    root@unknown:/tmp/home/root# mount -t davfs https://dav.box.com/dav /mnt/box
    mount.davfs: the server certificate is not trusted
      issuer:      GeoTrust Inc., US
      subject:     Box, Inc., Los Altos, California, US
      identity:    *.box.com
      fingerprint: c0:f7:f1:a6:34:42:d6:69:b1:90:41:a6:56:12:d6:a5:f9:60:57:ba
    You only should accept this certificate, if you can
    verify the fingerprint! The server might be faked
    or there might be a man-in-the-middle-attack.
    Accept certificate for this session? [y,N]
    I tried using the startup script shown below, which works on the command line to pass through that message, but doesn't work in script form.
    mkdir /mnt/box
    echo 'y' | mount -t davfs https://dav.box.com/dav /mnt/box
    I saw a few forum discussions about adding the certificate in PEM format, but that seems really intense and I'm looking for something a little easier if possible. I'm assuming this is something I don't know enough about to know the easy way of doing it. Any suggestions?
    Jun 2015
    Longmont, CO
    Resolved! I changed the script over to the WAN up and all is working now. Thanks for all the help!
  1. Entware для роутеров на платформе ARM (Asus RT-N18U/AC56U/AC68U/AC87U)
    By Radjah in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 29-01-2019, 09:11
  2. Replies: 220
    Last Post: 06-02-2016, 11:53
  3. Replies: 91
    Last Post: 01-03-2013, 17:00
  4. Установка и настройка софта EntWare на Asus RT-N66U
    Last Post: 05-06-2012, 14:48
  5. mount NAS on asus wl500gp
    By tex in forum WL-500gP Q&A
    Last Post: 07-12-2011, 19:28
