Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: Firmware v1.7.5.6 CR2.1 [Oleg]
    Personally I've not tested this, because I do not use client mode. That's why I'm asking you to do this.
    As for existing association - this due to the fact wl module was previously in AP mode and shoing garbage to you. Don't worry - new firmware will switch it to the right state with no broken association.
    As for loops - I think there will be one like this
    while sleep 15s; do if ! $(wl assoc | grep -q BSSID); then wl join $(nvram get wl0_ssid); fi; done
    This will catch reassociation (in case APs signal is lost) also. Try this one, but perform wl disassoc before it (hope this helps now).
    Czech Republic
    Oleg, your script works fine but it's not necessary to keep it running all the time. You can exit as soon as the first successful join is made. Otherwise you should exit with error status after while (in case the signal is poor or none). That's why I put the LIMIT variable into my stupid script - as per my experience - if you can't connect in about 30 seconds, it does not make sense to continue associating. There's no problem with loosing signal as I already tried to explain in my previous post. So you don't need to fix that situation by permanently running script. The join script should be initiated during the boot (only if the router is configured for Client mode of course) and occassionally by activating some Connect button in web configurator (so user could perform it anytime - perhaps another variable instead of router's SSID should be used).
    BTW, AFAIK some concurrent APs with client mode support can connect using BSSID (MAC address in fact). Maybe I was blind but I did not find any possibility to use that parameter in WL-500g so far. As some access points does not use SSID at all, it's hard to associate them...
    Hm, but suppose your wl500g see 2 APs and the current dies - do we need to reassociate with it? I think yes, that's why the script should run continously. Any thoughts?
    As for BSSID - how to associate using it it?
    Czech Republic
    Well, usually there are only AP's with unique SSID's in range. I can't easily check it but I think in case there are two APs with the same SSID, you will be probably automatically reassociated to the AP with better signal level.
    You can be sure the reassociation works automatically without any problem - really NO need to run join again - just one time (or better say until successful association) is enough. Works perfectly for me (joined AP manually 2 months ago) - I have unplugged the antenna many times for a long time. The RSSI and NOISE was frozen then and BSSID changed to all zeroes. After connecting antenna back to router, the these variables returned back to actual values and I could ping to remote AP again without any additional procedure.
    That's what I would really like to know... In my opinion it's not possible on WL-500g with current wl module. But D-Link uses that way of association: http://support.dlink.com/techtool/DW.../adv_mode.html
    It allows to connect concrete AP even if there are APs with the same SSID (sometimes it's a disadvantage of course - it would be nice to have both options).
    Last Post: 14-04-2005, 00:26
    Last Post: 11-01-2005, 19:22
    Last Post: 06-10-2004, 09:12
  4. Firmware v1.7.5.6 CR2 [Oleg]
    Last Post: 05-05-2004, 04:10
    Last Post: 07-04-2004, 18:22
