Log looks perfectly normal. Are you sure your hd isn't formatted ntfs?
hello,
i tried to use an external hdd case with an ibm hdd with my 500g, but I can`t login via ftp. what could be the problem? I´m neebie :-(
and what means that?
Apr 28 19:14:20 WL500g user.warn klogd: Vendor: IBM-DJNA Model: -351520 Rev: 0811
Apr 28 19:14:20 WL500g user.warn klogd: Type: Direct-Access ANSI SCSI revision: 02
Apr 28 19:14:20 WL500g user.warn klogd: Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
Apr 28 19:14:20 WL500g user.warn klogd: SCSI device sda: 30033360 512-byte hdwr sectors (15377 MB)
- andy
Ok...
really stupid question, but it has to be asked.
Did you set the "Enable FTP Server" to "yes" in the USB Application/FTP Server page?
Royan
yes :-)Originally Posted by Royan
and its fat-formatet.
- andy
ok try this:
open this page
http://my.router/Main_AdmStatus_Content.asp
be sure your harddisk contains data/directories
enter this command:and press REFRESH button Enter only will not work.Code:ls /mnt/usbfs/
if you see nothing enter this command:presh REFRESH again ofcourse.Code:mount
copy and paste the output here please
no response ;-)Code:ls /mnt/usbfs/
if you see nothing enter this command:/dev/root on / type cramfs (ro)Code:mount
none on /dev type devfs (rw)
none on /proc type proc (rw)
/ramfs on /mnt/ramfs type ramfs (rw)
- andy
I've got exactly the same problem. How do you mount the disk manually ?
ok, so nothing is mounted
try those commands and copy the output here:
Code:ls /dev/scsi/host0/bus0/target0/lun0/Code:ls /dev/scsi/Code:cat /proc/partitions
discCode:ls /dev/scsi/host0/bus0/target0/lun0/
part1
part2
part3
part4
host0Code:ls /dev/scsi/
[/QUOTE]Code:cat /proc/partitions
major minor #blocks name
8 0 15016680 scsi/host0/bus0/target0/lun0/disc
8 1 839922362 scsi/host0/bus0/target0/lun0/part1
8 2 269488144 scsi/host0/bus0/target0/lun0/part2
8 3 699181456 scsi/host0/bus0/target0/lun0/part3
8 4 10668 scsi/host0/bus0/target0/lun0/part4
try
mount -t vfat /dev/scsi/host0/bus0/target0/lun0/part1 /mnt/usbfs
or
mount -t ntfs /dev/scsi/host0/bus0/target0/lun0/part1 /mnt/usbfs
nothing happens....Originally Posted by Oleg
try after applying the commands from olegOriginally Posted by andy99
make sure there are some files at partition1Code:ls /mnt/usbfs/
after olegs commands my browser hangs up and with your command i get no response :-(Originally Posted by Antiloop
ok, anyway your problem is almost for sure in the partitioning. so make sure you have 1 PRIMARY partition (it may not be logical!)
you can use Partition Magic 8 to do this eventually (windows xp does not support fat32 bigger than 32gb or something)
after you've done this hook up your usb drive to your wl500g, and reboot it.
and try again
should be working then
partition manager says:
1 primary partition
mounted as "drive z"
fat32
14,3gb space
that should be right but it doesn`t work
- andy
