Hi
Try with #!/bin/shOriginally Posted by epimenides
you could add also in second line
logger post-firewall start
to see in syslog's the fact the script start
Hi guys,
i am using firmware 1.9.2.7-6b (2005-06-30) with my Asus wl-500g. Since I want to customize the default firewall with my own settings, I "installed" the
post-firewall script as described. Unfortunately the scripts doesn't get executed after startup.
SCRIPT:
#/bin/sh
# Environment settings:
IPTABLES=/usr/sbin/iptables
# Disable ICMP echo reply to wan:
$IPTABLES -I INPUT 1 -s ! 192.168.1.0/24 -p icmp -j DROP
DIRECTORY:
drwxr-xr-x 1 admin root 0 Aug 4 13:42 .
drwxr-xr-x 1 admin root 0 Jan 1 2000 ..
-rwxr-xr-x 1 admin root 35 Aug 4 13:43 post-boot
-rwxr-xr-x 1 admin root 158 Sep 19 13:19 post-firewall
The script "post-boot" is working perfectly, so what i am doing wrong? Is there a bug in the firmware?
Thanks,
Epimenides
P.S.: Thanks to Oleg for his great work!
Hi
Thank you, it helped!
