Results 1 to 3 of 3
Thread: WL-HDD IDE Speed -- Could be faster?
    Hello,
    I have an ATA-100 drive in my WL-HDD and I suspect that it's running slower than 100MHz. Based on some other WL-HDD performance discussions, this may not matter in the grand scheme of things, but I'm still curious. I was sifting through the kernel log and early on it says:
    kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
    Later, I see:
    kernel: ide0: BM-DMA at 0x0140-0x0147, BIOS settings: hdaMA, hdbio
    which suggests that my harddrive (hda) is actually using DMA and not PIO. So far so good. Later still I see:
    kernel: hda: 195371568 sectors (100030 MB), CHS=12161/255/63, UDMA(33)
    which suggests that I'm using UDMA (good) but only at 33MHz (bad). At the shell prompt, cat /proc/ide/hda/settings reports (among other things):
    name value min max mode
    current_speed 66 0 69 rw
    using_dma 1 0 1 rw
    Does this mean the harddrive is actually using UDMA66? Can I jack it up to 100 somehow?
    Thanks,
    Massi
    Apr 2004
    Netherlands
    I guess that any (U)DMA speed: 33, 66, 100 or 133 will give you the same performance and that the critical part of the performance is the (U)DMA/PIO setting. A harddisk with (U)DMA 33 speed will deliver far more data to the processor than the processor can handle.
    Use hdparm to adjust your harddisk settings... but you wont get any faster speed than 6-8 MB/s at all.
    hdparm is not in Oleg's firmware, so you have to get it via ipkg or search for it in the forum.
    Test your speed with: hdparm -t /dev/discs/disc0/disc
  1. Custom Firmware any faster?
    By Leehro in forum WL-HDD Q&A
    Last Post: 11-09-2005, 05:43
  2. slow speed in msn
    By tthen in forum WL-500g Q&A
    Last Post: 18-02-2005, 20:22
  3. FTP and speed question
    By ebk71 in forum WL-HDD Q&A
    Last Post: 12-01-2005, 12:38
  4. FASTER PRINTING: extra printer memory
    By xlephant in forum WL-500g Custom Development
    Last Post: 29-10-2004, 13:52
