Jan 1 00:00:12 kernel: hub.c: 2 ports detected
Jan 1 00:00:12 kernel: usb.c: registered new driver usblp
Jan 1 00:00:12 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 00:00:14 kernel: usb.c: registered new driver audio
Jan 1 00:00:14 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 00:00:15 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 00:00:15 kernel: Initializing USB Mass Storage driver...
Jan 1 00:00:15 kernel: usb.c: registered new driver usb-storage
Jan 1 00:00:15 kernel: USB Mass Storage support registered.
Jan 1 00:00:26 kernel: VFS: Can't find ext3 filesystem on dev ide0(3,1).
Jan 1 00:00:26 kernel: MSDOS FS: Using codepage 950
Jan 1 00:00:26 kernel: MSDOS FS: IO charset cp950
Jan 1 00:00:26 kernel: FAT: bogus logical sector size 0
Jan 1 00:00:26 kernel: VFS: Can't find a valid FAT filesystem on dev 03:01.
Jan 1 00:00:26 kernel: FAT: freeing iocharset=cp950
Jan 1 00:00:26 kernel: attempt to access beyond end of device
Jan 1 00:00:26 kernel: 03:02: rw=0, want=2, limit=1
Jan 1 00:00:26 kernel: EXT3-fs: unable to read superblock
Jan 1 00:00:26 kernel: VFS: Can't find a valid FAT filesystem on dev 03:02.
Jan 1 00:00:26 kernel: kjournald starting. Commit interval 5 seconds
Jan 1 00:00:26 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Jan 1 00:00:26 kernel: EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,5), internal journal
Jan 1 00:00:26 kernel: EXT3-fs: recovery complete.
Jan 1 00:00:26 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 00:00:26 USB storage: ext3 fs mounted to /tmp/harddisk
Jan 1 00:00:26 FTP server: daemon is started
