That means? :-)
PSP can only connect to AP's.
Do you have a problem with your Asus? -> UTFS
Newisys NA-1400 NAS info (4x hotswap SATA, 2x gigabit ethernet, 2x USB 2.0)
That means? :-)
Nothing much actually
But, I've found an interesting site with lots of info on the PSP: http://pspcrazy.com/
1. anyone using this setup? im planning to get a wl-hdd and im just wondering if the wl-hdd can stream mp3s to PSP? the PSPis capable of playing internet radio from shoutcast servers. is there a shoutcast server for wl-hdd?
2. another thing is, based on what i have read so far, wl-hdd can become mp3 player by plugging a USB-soundcard or usb-frm-transmitter in the usb port and can be controlled by a pc in the network. if it can be controlled thru a web browser, is it possible to use the PSP as a remote control thru the web browser built-in to the psp firmware 2.x?
i dont own a wl-hdd yet but planning to get one soon cause i have a toshiba 2.5 hdisk 80gb which im planning to fill-up mp3s and some files for sharing in my home network. thanks in advance.
Is there someone who succeded in connection a PSP to internet through a wl500G???
I've been trieing for hours and still without any luck.
I know that there are a lot of troubles with some implementations in the PSP.
But is there someone who really made this work?
I would really like to hear al the details of the settings that where used.
The PSP has already been updated to firmware 2.5
So no-one was able to connect his/hers PSP to a WL500G????
Did you try http://http://www.us.playstation.com...roubleshooting ?
You'd probably have better luck getting advice if you gave info on what you have tried and what error messages you get.
I myself have my PSP working with the wl500gx.
LK
Yep, i've tried everything from this site.....Originally Posted by beatnick
So now I know that is IS possible....I almost gave up....Originally Posted by LeperKing
Can you please tell me what firmware version you use?
Also I would like to know what type of encryption you use.. wep/wpa and that type of settings.
If I have these basic answers I can try to copy the result.
Please help
WPA-TKIP Firmware 2.6
That is a good start!Originally Posted by LeperKing
I did not use WPA so far, because there is one laptop in the network which does not support this. (Old wireless card)
But if this works I will exchange the wireless card of the laptop.
What firmware did you use on the router???
1.9.2.7-6b (Oleg)
Have you actually tried connecting the psp??????? As per my original post what error messages did you get!!!!!!!!
LK
The problem is that it is not my own network but from some-one else....so I've been trying for 2 hours without any luck.Originally Posted by LeperKing
And I'm not exactly a newby to wireless coms :-)
I even tried an unprotected network but this didn't even work.
SSID is vissible all the time and I even tried different channels.
Most of the time I got "not able to make a connection" or "unable to retrieve a ip adres.
All error messages were in Dutch ofcourse
But now I know that it is possible I will give it a try again.
Thanx for the advice!!
?? which PSP firmware you all got
I have no problems connecting my PSP with the 500g
But I have to say that I have 1.50 on my PSP, so I can't use WPA. I have to use WEP for encryption, and it works fine.
mac filtering is on, wep128 is on
no problems
