Results 1 to 4 of 4
Thread: How to start samba daemon automatically after reboot
    Question How to start samba daemon automatically after reboot
    I've changed /etc/smb.conf for custom shares. Then I issued:
    echo "/etc/smb.conf" >> /usr/local/.files && flashfs save && flashfs commit && flashfs enable
    Now everything works as I want. But when I reboot the router, the /etc/smb.conf is loaded with default values.
    So according to: http://wl500g.info/showthread.php?10...0936#post60936 I made the custom changes again, save&commit&enable, disabled samba via webinterface and made a save&restart.
    After restarting the custom settings in smb.conf stayed the same, but the shares are no longer working - looks like samba daemon is not running. How can I start it manually? Or where should I enable it?
    The Netherlands - Eindhoven
    Go to the web admin of oleg firmware. You can configure samba under "USB Application -> Samba"
    Every time the router restarts, a fresh configuration file will be generated, and thus these settings you made will be lost.
    You could also try installing optware samba, also mentioned in wengi's tutorial.
    Is it possible to configure SAMBA via web interface to use advanced security as described here - http://wl500g.info/showthread.php?31...-login-by-user ?
    Quote Originally Posted by newbiee View Post
    sure, for samba 3 a standard config is this:
    [global]
    	netbios name = Router
    	guest account = admin
    	server string = Router
    	guest ok = Yes
    	workgroup = MSHOME
    	os level = 255
    	interfaces = 192.168.2.1/24
    	username map = /opt/etc/samba/user.map
    	domain master = Yes
    	hosts allow = 192.168.1.0/24
    	encrypt passwords = yes
    	security = share
    	dns proxy = No
    	wins support = true
    	preferred master = yes
    [movies]
    	comment = Movies
    	path = /tmp/mnt/disc0_1
    	read only = No
    Only thing you need to do is add the user security etc.
    I recommend installing samba36 from ipkg (you have ipkg right?)
    ipkg install samba36
    configuration will be placed in /opt/etc/samba
  1. Asus start niet op.
    By duckie112 in forum Dutch Discussion - Nederlands
    Last Post: 26-04-2013, 19:33
  2. laptop A8Jseries start met batterij niet op, zonder batterij wel.
    By WillemdeNie in forum Dutch Discussion - Nederlands
    Last Post: 22-02-2013, 09:00
  3. Mac Os X и Samba
    By Dared in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 30-10-2012, 13:33
  4. Oleg firmware/Samba 2.2.12 and OS X 10.7.2 Lion - No more Samba ?
    By QMax in forum WL-500gP Firmware Discussion
    Last Post: 29-04-2012, 20:49
  5. How to start builtin Telnet daemon
    By schriss in forum WL-500w Tutorials
    Last Post: 05-09-2007, 01:15
