Well nerodark am not a linux guru so please be patient with my questions.
Before I followed your instructions I had everything running perfect from Mascat's tutorials even the rrdtool.....but I am still not able to use Wi-viz.
Files were exctracted succesfully and all the directories were created ok.
What I did with cron is I created a /opt/etc/cron.5mins/wiviz.sh including :
/opt/share/usr/sbin/wiviz
After saving to flash, rebooting and waiting for 10-15 min I got no results trying to access the webpage and I also cant see the images created from rrdtool. "500 Internal Error" while I can access my test web page at http://router_ip:81
trying to run wiviz directly gives me the following:
root]$ /opt/share/usr/sbin/wiviz
Wi-Viz infogathering daemon by Nathan True
Wireless magic not correct, not querying wl for info
Loading config file
Wiviz: No config file (/tmp/wiviz-cfg) present, using defaults
Failure to open pcap!
Err=ioctl: No such device
What I cant follow in your tutorial is :
i) what do you mean "You need another http daemon because you cannot extract the Wi-viz files to the default www directory, you have to extract them to read/write path." and how am I supposed to do this ?
ii) Can you give some more information regarding the cron set up part of your tutorial?
Thank you in advance for your help.
