Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 70
Thread: UPS Ippon и роутер Asus
    Quote Originally Posted by kvazimoda24 View Post
    Спасибо за советы, собрать драйвера я собрал, но вот работать они всё-равно не работают, в целом, ничего не изменилось:
    А megatec.c подправили? У меня с
    #define READ_PACE    10000 /* 300000 */  /* interval to wait between sending a command and reading the response (usec) */
    , работает нормально.
    Nov 2006
    • С какой именно прошивкой экспериментируете?
    • UPS через хаб подключаете или напрямую?
    • usb 2.0 выключать пробовали (модуль ehci-hcd)?
    Запустите с -DDDDD.
    # megatec_usb -a Ippon -u root -DDDDDDDDDDDDDDDDDDDDDDDDD
    Network UPS Tools - Megatec protocol driver 1.6 (2.4.1)
    Serial-over-USB transport layer 0.10
    debug level is '25'
    Checking device (0000/0000) (002/001)
    - VendorID: 0000
    - ProductID: 0000
    - Manufacturer: Linux 2.4.20 ehci_hcd
    - Product: PCI device 14e4:471a
    - Serial Number: 00:03.1
    - Bus: 002
    Trying to match device
    Device does not match - skipping
    Checking device (0424/2502) (002/002)
    - VendorID: 0424
    - ProductID: 2502
    - Manufacturer: unknown
    - Product: unknown
    - Serial Number: unknown
    - Bus: 002
    Checking device (0665/5161) (002/003)
    - VendorID: 0665
    - ProductID: 5161
    - Manufacturer: Cypress Semiconductor
    - Product: USB to Serial
    - Bus: 002
    Device matches
     none (-22)
    DTR=1, RTS=0
    Starting UPS detection process...
    Asking for UPS information [I]...
     none (-22)
    I => FAILED [short read]
    I detail: (1 bytes) => 49
    Asking for UPS status [Q1]...
     none (-22)
    Q1 => FAILED [timeout]
     none (-22)
     none (-22)
     none (-22)
     none (-22)
     none (-22)
     none (-22)
     none (-22)
    ser_send_pace: Device detached? (error -1: error sending control message: Broken pipe)
    = device has been disconnected, try to reconnect =
    - VendorID: 0000
    - ProductID: 0000
    - Bus: 002
    - VendorID: 0424
    - ProductID: 2502
    - Product: unknown
    - Bus: 002
    - VendorID: 0665
    - ProductID: 5161
    - Bus: 002
    Device matches
    Successfully reconnected
     none (-22)
    5 out of 5 detection attempts failed (minimum failures: 2).
    Megatec protocol UPS not detected.
    $ awk 'NR==71 {print $0}' megatec.c
    #define READ_PACE    100000  /* interval to wait between sending a command and reading the response (usec) */
    Product ID: WL500gpv2
    Firmware Version: 1.9.2.7
    Firmware Release: 1.9.2.7-10
    Подключаю напрямую в нижний USB разъём, в верхний воткнут хард на 250 гигов.
    Только-что попробовал, если я выполняю # rmmod ehci-hcd, то у меня отрубается винчестер и я его примонтировать снова не могу, я даже не могу после этого выполнить команду # ls /dev, выдаёт что-то типа "Юзер сигнал 1".
    Nov 2006
    Понял, ядро старенькое 2.4.20. Придется тебе самому в нем копаться... Могу только дать некоторые наводки:
    • Если окажется, что после отключения usb 2.0 всё заработало, то причина в дополнительных проверках в ehci-hcd. А именно, скорее всего, urb->interval не выставляется в drivers/usb/devio.c в функции proc_submiturb(). Код можно слизать из 2.6, для ядра 2.4.37 это должно выглядить так - 242-usb-devio.patch
    • Ежели отключение usb 2.0 не поможет, то единственный быстрый и тупой вариант пройтись по drivers/usb/usb.c, hcd.c, drivers/usb/host/*.c и вставить доп. отладку везде, где возвращается -EINVAL. Или расставить уникальные коды, и по изменившемуся коду ошибки понять где-же сбоит проверка.
    надо отключить usb 2.0 до подключения винта или отмонтировать винт в момент передергивания.
    Я не знал, что есть более новые прошивки, только что скачал и установил самую новую, которую нашёл:
    Firmware Release: 1.9.2.7-d-r308
    После этого я всё-таки смог отключить USB 2.0, прямо через WEB-интерфейс. И бесперебойник заработал.
    А не могли бы выложить готовый собранный модуль ehci-hcd, если он, конечно уже есть собранный. Потому как, я не представляю себе как собрать ядро для роутера, чтобы оно работало на нём. Я так понимаю, надо же собирать под конкретный процессор, а выбрать такой процессор в настройщике ядра нельзя
    Или я чего-то не понимаю?
    ну и здорово, начиная с 1.9.2.7-d-r357 должно работать без отключения usb 2.0
    Nov 2006
    Это наша коллективная помощь Олегу Если у него вновь появится время, тогда вообще будет супер-круто
    Буду пробовать исправлять драйвера usb
    Я уже подправил в SVN, проще попробовать собрать r358 и посмотреть насколько я был прав. Ну а нет, дальше будем копать...
    У меня уже мозги кипят, будте добры, киньте в меня ссылкой чтоли, где можно прочитать про то, что такое SVN и как можно собрать самому прошивку r358. И где куча предыдущих прошиок, я на сайте http://code.google.com/p/wl500g/ смог найти толь WL500gpv2-1.9.2.7-d-r308.trx. Я так понимаю есть где-то еще 49 версий...
    http://code.google.com/p/wl500g/wiki...CustomFirmware
    Спасибо, вечерком попробую, будем надеяться, что после такой прошивки этот серебристый зверёк не умрёт
    Еще уменьшите задержку! У меня стоит 10000, а увас 100000 т.е. в десять раз больше! USB 2.0 я не отключал, IPPON 2000 работает на ура!
    Когдя я, наткнувшись на эту проблему, ковырял этот драйвер, то обнаружил, что UPS гонит данные в USB, в отличии от COM, без задержекn и на большей скорости, в результате из-за задержки буфер переполняется и начинает переписываться! Совсем убирать задержку не стал, т.к. не знал, на что она еще влияет, по этому просто стал ее уменьшать, при уменьшении значения до 100000 срабатывало, но как-то не стабильно, а вот с уменьшением еще в 10 раз, т.е. до 10 000 работает отлично!
    Попробовал написать десять тысяч. Ничего не изменилось, ну разве что пролетает все гораздо быстрее, а так, ни ответа, ни привета, а при отключенном USB 2.0, всё работает, но уж больно медленно работает с винчестером, так что занялся я сборкой прошивки. О результатах отпишу.
    Значит так, начал собирать прошивку и застопорился на пункте 4.3:
    $ make
    [ ! -d libbcmcrypto ] || make -C libbcmcrypto  EXTRACFLAGS="-mips32 -mtune=mips32 -Wno-pointer-sign  -DBCMWPA2 "
    find: `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/mipsel-uclibc/target': No such file or directory
    make[1]: Entering directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libbcmcrypto'
    make[1]: Nothing to be done for `all'.
    make[1]: Leaving directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libbcmcrypto'
    [ ! -d libusb ] || make -C libusb  EXTRACFLAGS="-mips32 -mtune=mips32 -Wno-pointer-sign  -DBCMWPA2 "
    make[1]: Entering directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb'
    make  all-recursive
    make[2]: Entering directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb'
    Making all in .
    make[3]: Entering directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb'
    make[3]: Nothing to be done for `all-am'.
    make[3]: Leaving directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb'
    Making all in tests
    make[3]: Entering directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb/tests'
    /bin/sh ../libtool --mode=link mipsel-uclibc-gcc  -O2 -mips32 -mtune=mips32 -Wno-pointer-sign -Wall   -o testlibusb  testlibusb.o ../libusb.la
    mipsel-uclibc-gcc -O2 -mips32 -mtune=mips32 -Wno-pointer-sign -Wall -o .libs/testlibusb testlibusb.o  ../.libs/libusb.so
    /home/kvazimoda/Загрузки/For_Router/New_Firmware/brcm/hndtools-mipsel-uclibc-4.1.2/bin/../lib/gcc/mipsel-linux-uclibc/4.1.2/../../../../mipsel-linux-uclibc/bin/ld: BFD 2.17 assertion fail elflink.c:6261
    /home/kvazimoda/Загрузки/For_Router/New_Firmware/brcm/hndtools-mipsel-uclibc-4.1.2/bin/../lib/gcc/mipsel-linux-uclibc/4.1.2/../../../../mipsel-linux-uclibc/bin/ld: .libs/testlibusb: hidden symbol `__fini_array_end' in .libs/testlibusb is referenced by DSO
    /home/kvazimoda/Загрузки/For_Router/New_Firmware/brcm/hndtools-mipsel-uclibc-4.1.2/bin/../lib/gcc/mipsel-linux-uclibc/4.1.2/../../../../mipsel-linux-uclibc/bin/ld: final link failed: Nonrepresentable section on output
    make[3]: *** [testlibusb] Error 1
    make[3]: Leaving directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb/tests'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb'
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/kvazimoda/Загрузки/For_Router/New_Firmware/Derevo/broadcom/src/gateway/libusb'
    make: *** [libusb] Ошибка 2
    Судя по тому, что я смог разобрать, сборка стопорится на чем-то, что связано как раз с usb...
    Чудеса, да и только. Кстати, посмотрел ваше первое сообщение и нашел там такое:
    $ cat /opt/etc/ups.conf
    [Ippon]
    driver = megatec_usb
    port = /dev/usb/hiddev0
    , у меня стоит port = auto
    [Ippon]
    [Ippon]
    port = auto
    vendorid = 0665
    Народ, может кто соберёт прошивочку для меня, а то ну никак не могу разобраться в чём дело, почему стопорится... Делаю все по инструкции: Сборка прошивки. Стопорюсь на пункте 4.3. Вывод команды make приводил чуть выше.
  1. Новый роутер Asus RT-N12 B1/C1/D1/HP/VP
    Last Post: 03-05-2015, 15:29
  2. Проблемы с интернет. Роутер Asus WL-500
    By SCREAM in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 30-12-2012, 11:21
  3. ICQ и роутер Asus WL-500gP
    By ZeusEX in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 14-07-2012, 22:49
  4. Принтер Brother и роутер Asus
    By Plimouthrock in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 01-09-2010, 23:11
