Results 1 to 8 of 8
Thread: Asus PCE-AC66 Dual-Band PCI-e Adapter
    Arrow Asus PCE-AC66 Dual-Band PCI-e Adapter
    ASUS PCE-AC66 Dual-Band PCI-E Adapter 802.11ac Wireless-AC1750
    ASUS PCE-AC66 Next Generation AC Dual-Band Wireless Adapter IEEE 802.11ac,
    802.11b/g/n PCI Express Up to 1750Mbps (450/1300Mbps) Wireless Data Rates
    • IEEE 802.11ac, IEEE 802.11b/g/n
    • Up to 1750Mbps (450/1300Mbps) Wireless Data Rates
    • 2.4GHz/5GHz
    Release Date: 12/31/2012 - http://www.newegg.com/Product/Produc...82E16833320136
    Asus PCE-AC66 BCM4360 PCI Express 3 x 3 802.11ac 1.3Gbps (5GHz) + 450Mbps (2.4GHz)
    Asus USB-AC53 BCM43526 USB port 2 x 2 802.11ac 867Mbps (5GHz) + 300Mbps (2.4GHz)
    • BCM4360 supports PCIe interface and implements 3-stream 802.11ac specifications, and reaches speeds up to 1.3 Gbps.
    • BCM4352 supports PCIe interface; implement 2-stream 802.11ac specification to reach up to 867 Mbps.
    • BCM43526 supports USB interface; implement 2-stream 802.11ac specification to reach up to 867 Mbps.
    • BCM43516 supports USB and reaches speeds of up to 433 Mbps with its single stream 802.11ac implementation.
    http://www.broadcom.com/press/release.php?id=s637241
    Full 802.11ac product lineup
    In addition to the RT-AC66U router, ASUS has also released the PCE-AC66 and USB-AC53 clients, both capable of 802.11ac speeds.
    The dual-band PCE-AC66 offers a PCI Express client card for desktops, with 3 x 3 high-powered transmission. It can sustain 1.3Gbps
    in 5GHz and up to 450Mbps in the 2.4GHz band. For easy USB upgrades to 802.11ac, the USB-AC53 compact dongle plugs into any
    USB port, with 2 x 2 802.11ac. In 5GHz, the attachment can maintain 867Mbps, while in 2.4GHz it works at 300Mbps, achieving a
    total throughput of around 1.3Gbps. The PCE-AC66 and USB-AC53 are enabled by Broadcoms 5G WiFi chips, and demonstrate ASUS
    technology leadership in bringing an 802.11ac ecosystem to consumers.
    http://www.asus.com/News/rZcy4jXiQPQ5F8YL/
    ASUS PCE-AC66 Dual-Band PCI-E Adapter which is capable of 802.11ac speeds. This dual-band PCE-AC66 offers a PCI Express client card for desktops,
    with 3 x 3 high-powered transmission. It can sustain 1.3Gbps in 5GHz and up to 450Mbps in the 2.4GHz band.
    The PCE-AC66 are enabled by Broadcoms 5G WiFi chips, and demonstrate ASUS technology leadership in bringing an 802.11ac ecosystem to consumers.
    http://www.facebook.com/media/set/?s...6439115&type=1
    The Netherlands - Eindhoven
    Wow, looks great
    if only they'd also make something like an ea-n66 but then with ac would be great
    Arrow Asus PCE-AC66
    Asus PCE-AC66 802.11ac Dual-band Wireless-AC1750 PCI-E Adapter
    • 5th generation 802.11ac chipset gives you dualband 2.4GHz/5GHz for up to superfast 1.30Gbps
    • Flexible extended antenna placement helps you pinpoint the best reception in your environment
    • Instant Wi-Fi upgrade for your desktop: no more messy Ethernet cables needed
    • High-power design clears up dead zones with 150% greater coverage
    • Custom heatsink dissipates heat for more stable and reliable non-stop operation
    http://www.asus.com/Networks/Wireless_Adapters/PCEAC66/
    Specifications
    Network Standard IEEE 802.11ac
    Antenna 3 x R SMA Antenna
    Operating Frequency 2.4GHz/5.1~5.8GHz
    Operation Channel 11 for N.America, 13 Europe (ETSI)
    Data Rate 802.11ac: downlink up to 1300Mbps,
    uplink up to 1300Mbps(20/40MHz)
    Output Power b mode : 24.5 dBm
    g mode : 19 ~23 dBm
    n mode : 18 ~22 dBm
    Modulation CCK, DQPSK, DBPSK, OFDM
    Management Transmission power adjustment
    Wireless configuration
    Utilities Wireless setting
    Security 64-bit WEP, 128-bit WEP,
    WPA2-PSK, WPA-PSK
    Certificates CE, FCC, C-Tick, IC, NCC
    Dimensions 103.3 x 68.9 x 19 mm (WxDxH)
    Weight 125 g (Device Only)
    OS Support Windows 8
    Windows 7
    Windows 2000
    Windows XP
    ftp://ftp.asus.com.tw/PUB/ASUS/wireless/PCE-AC66
    Wow, looks great
    Versatile 3in1 Function: Access Point, Wi-Fi Bridge, and Range Extender Mode:
    http://www.asus.com/Networks/Wireless_Adapters/EAN66/
    Dual-band Wireless USB Adapter:
    http://www.asus.com/Networks/Wireless_Adapters/USBN66/
    http://www.asus.com/Networks/Wireless_Adapters/USBN53/
    http://www.wikidevi.com/wiki/ASUS_USB-AC53
    Dual-Band Wireless PCI-E Adapter:
    http://www.asus.com/Networks/Wireless_Adapters/PCEN53/
    http://www.wikidevi.com/wiki/ASUS_PCE-AC66
    Seems to be out in the US: http://www.newegg.com/Product/Produc...82E16833320136
    With one very happy customer:
    Pros: SPPPPEEEEEEDDDDD - This unit tied to the RC - AC66U Router is by far the most amazing speed upgrade I have made to my system since Comcast Broadband 10 Years ago...
    Cons: People are complaining about it being a BETA setup 802.11ac has not been finalized... SO what Upgrade both and who cares if it takes a firmware upgrade later... I am getting throughput speeds on just MY USB N adaptor that I have never seen before.. and the connection using this PCI-E unit and the router are just absurd!?!!?
    Other Thoughts: You will be blown away by the SPEED and Range of this unit tied to a AC1750 Type router.. I recommend the ASUS 66u as does most reviewers on the market today.
    lol
    Taiwan_Excellence
    http://www.taiwanexcellence.org/inde.../102116AB-A040 RT-AC67U
    402 華碩電腦股份有限公司 802.11ac Gigabit 極致尊爵內建雙天線同步雙頻無線路由器 RT-AC56U
    403 華碩電腦股份有限公司 1300 PCE 無線外接式天線網卡 PCE-AC66
    404 華碩電腦股份有限公司 802.11ac Gigabit 同步雙頻無線路由器 RT-AC66U
    405 華碩電腦股份有限公司 雙頻無線 USB 網卡 USB-N66
    406 華碩電腦股份有限公司 802.11ac 極速飆網雙頻無線分享器 RT-AC67U
    407 華碩電腦股份有限公司 High Power 9db ix 2 無線分享器 RT-N12HP
    408 華碩電腦股份有限公司 Wireless-N750 雙頻Gigabit無線路由器 RT-N65U
    409 華碩電腦股份有限公司 雲端家庭黑鑽無線路由器 RT-N14U C1
    410 華碩電腦股份有限公司 PadFone 2 - A68
    411 華碩電腦股份有限公司 雙頻無線 N600 網路中繼器 RP-N53
    412 華碩電腦股份有限公司 四合一無線攜帶型路由器 WL-330NUL
    http://www.taiwantrade.com.tw/CH/download/1586061
    402 華碩電腦股份有限公司 802.11ac Gigabit DualBand Wireless-AC1200 Router RT-AC56U
    403 華碩電腦股份有限公司 802.11ac DualBand Wireless-AC1750 PCIe Adapter PCE-AC66
    404 華碩電腦股份有限公司 802.11ac Gigabit DualBand Wireless-AC1750 Router RT-AC66U
    405 華碩電腦股份有限公司 DualBand Wireless-N900 USB Network Adapter USB-N66
    406 華碩電腦股份有限公司 802.11ac DualBand Wireless-AC1900 Router RT-AC67U
    407 華碩電腦股份有限公司 High Power 9dbi x 2 Ant Wireless-N300 Router RT-N12HP
    408 華碩電腦股份有限公司 Gigabit USB 3.0 DualBand Wireless-N750 Router RT-N65U
    409 華碩電腦股份有限公司 Cloud 3G/4G DualWAN Wireless-N300 Router (MT7620) RT-N14U C1
    410 華碩電腦股份有限公司 DualBand Wireless-AC1200 USB Network Adapter USB-AC53
    411 華碩電腦股份有限公司 DualBand N600 Wireless range extender (MT7620) RP-N53
    412 華碩電腦股份有限公司 Mobile Wireless-N150 Router WL-330NUL
    Arrow Asus PCE-AC68
    Asus PCE-AC68 802.11ac Dual-band Wireless-AC1900 PCI-E Adapter
    http://www.asus.com/Networks/Wireless_Adapters/PCEAC68/
    Asus RT-AC68U
    • 802.11ac Concurrent Dual-band AC1900. (600Mbps/2.4GHz* + 1300Mbps/5GHz)
    • Two high speed and high powered USB ports for network storage and multifunction printer support.
    • 4 x Gigabit Ethernet ports. 1 x USB 3.0 + 1 x USB 2.0 ports for fast file and printer sharing.
    • High level current usage for superior download and gaming performance or multi client connections.
    * In order to reach 600Mbps/2.4 GHz, RT-AC68U must connect to the ASUS PCE-AC66/68 or RT-AC68U in media bridge mode.
    Specifications
    Interface PCI Express
    Product Segment AC1900 ultimate AC performance;
    600*Mbps (802.11n) + 1300Mbps (802.11ac)
    Data Rate 802.11a/b/g/n/ac : downlink up to 1300Mbps,
    uplink up to 1300Mbps (20/40/80MHz)
    Output Power ac mode : 18 ~22 dBm
    b mode : 22 dBm
    g mode : 19 ~22 dBm
    n mode : 18 ~22 dBm
    Modulation 64QAM, 16QAM, CCK, DQPSK, DBPSK, OFDM
    Management Wireless configuration
    connection management
    connection profile setup
    WPA2-PSK, WPA-PSK
    Certificates CE, FCC, IC
    Dimensions 103.3 x 68.9 x 21 mm (WxDxH)
    Windows 7
    Windows 2000
    Windows XP
    ftp://ftp.asus.com.tw/PUB/ASUS/wireless/PCE-AC68
  1. Asus PCE-AC66 Dual-Band PCI-e Adapter
    Last Post: 26-08-2013, 08:58
  2. USB-seriel Adapter feste tty zuweisen
    By Smuggler in forum German Discussion - Deutsch (DE)
    Last Post: 13-06-2012, 10:32
  3. WL500G as WiFi adapter client (connect to a hotspot)
    By jago25_98 in forum WL-500gP Q&A
    Last Post: 27-05-2012, 20:52
  4. Uplink Skype to SIP Adapter on WL500gP
    By piezomotor in forum WL-500gP Q&A
    Last Post: 08-01-2008, 20:25
