Results 1 to 8 of 8
Thread: Help with module please
    I am truing to set up a webcam on my wl-500gp v1.
    I had to compile the entire fw because i needed gspca_sonixb.ko
    Now when i try to use the module i get:
    install: cannot stat `/oleg/broadcom/src/gateway/mipsel-uclibc/modules/lib/modules/*/kernel/fs/ntfs/ntfs.ko': No such file or directory
    or using modprobe
    make[1]: *** [modules_install-usb] Error 1
    make[1]: Leaving directory `/oleg/broadcom/src/gateway'
    Oleg with gspca_sonixb.ko help please
    Nov 2006
    What the fuck i am supossed to do with them cause are compiled automaticaly duded. acording to the tutorial i am missing dependencies that i cannot install because my flash is readonly.
    Make kernel error
    I am in folder broadcom/src/1.9.2.7-rtn/
    When i run make kernel i get:
    ar -C kernel --exclude .svn -cf - arch drivers include sound | tar -C /oleg/broadcom/src/linux/linux-2.6 -xf -
    make[1]: Leaving directory `/oleg/broadcom/src/1.9.2.7-rtn/brcm-src-2.6'
    make -C kernel-2.6 extra-drivers
    make[1]: Entering directory `/oleg/broadcom/src/1.9.2.7-rtn/kernel-2.6'
    DRV gspca
    DRV usbip
    DRV uvc
    make[1]: Leaving directory `/oleg/broadcom/src/1.9.2.7-rtn/kernel-2.6'
    make -C kernel-2.6 patch
    Preparing kernel ...
    Looking for last applied patch
    Patching /oleg/broadcom/src/linux/linux-2.6 with buildhost.patch
    buildhost.patch
    Can not apply buildhost.patch cleanly
    make[1]: *** [patch] Error 1
    make: *** [kernel-patch] Error 2
    what i am doing wrong. help please
    what kind of revision do you use?
    remove src/linux/linux-2.6.22.19 directory and re-extract the kernel
    on the latest revision (4314) it worked fine
    i got the kernel from here
    http://wl500g.googlecode.com/files/l....22.19.tar.bz2
    Same error every time
    Quote Originally Posted by badboy1985ro View Post
    again, remove everything, do clean
    svn co of the source, unpack kernel and after that from 1.9.2.7-rtn dir do:
    make kernel
    make
    after that go to gateway dir and issue:
    make menuconfig
    make
    make images
  1. PL2303 module backport from 2.6.8 to 2.4.20
    By kodomo in forum WL-500g Custom Development
    Last Post: 24-07-2009, 20:20
