Do you've #!/bin/sh as the first line?
Yes, the links are correct.
After I had overcome all troubles with setting up the post-firewall script (to get the thttpd Server running) I realized that the script is not being called after reconnecting to ISP and rebooting the router.
post-boot and post firewall are in the same folder and post-boot is being executed.
As soon as I call:
both ports are reported as open and the webserver is working.Code:iptables -I INPUT 2 -p tcp --dport 80 -j ACCEPT iptables -I INPUT 2 -p tcp --dport 81 -j ACCEPT
Is it correct, that /usr/local is linked to /tmp/local ?
Code:[admin@(none) /usr]$ ls -F X11R6/ codepages/ lib/ sbin/ bin/ etc/ local@ tmp@ [admin@(none) /usr]$
this is my post-firewall:Originally Posted by Oleg
Code:[admin@(none) root]$ cat /tmp/local/sbin/post-firewall #!/bin/sh iptables -I INPUT 2 -p tcp --dport 80 -j ACCEPT iptables -I INPUT 2 -p tcp --dport 81 -j ACCEPT iptables -t nat -A PREROUTING -i $1 -p tcp --dport 80 -j DNAT --to-destination $4:81 [admin@(none) root]$
Which connection type do you have?
PPPoEOriginally Posted by Oleg
I have PPPoE Relay disabled, could this be the problem?
can you run the script manually? (ergo)Code:/tmp/local/sbin/post-firewall
(it would give back some error messages since variables such as $1 would not be recognized)
I think, I got it working now, I lost all my settings after changing something in the webinterface and restarting the router.
After setting up post-boot and post-firewall from scratch, the ports are finally open without me having to open them manually.
I'll wait until tonight (the next reconnect to the isp) in order to see if it really is working now. If not, I'll try to run the script as stated below.
Originally Posted by sup
