Results 1 to 2 of 2
Thread: Problem with WL-HDD and D-BOX
    Hi
    i have a small question.
    I have a ASUS WL-HDD and a DBOX2.
    My problem is:
    I want to connect to my dbox from my PC.
    PC wireless to -> WLAN Lancom ROUTER wireless to -> WL-HDD wired via lan to -> DBOX2.
    I have access the WL-HDD via WLAN but i have no access to my d-box.
    With the d-box i can ping my wl-hdd without any problems but i want to have a connection from my PC to my dbox. Does anybody have a solution for this problem.
    I´m using the newest ASUS Firmware 1.2.3.4.
    i tried to set my eth speed to 10 Mbit with et -i eth1 10half but without success.
    Is there any way to connect the lan devices at the wl-hdd via WLAN ???
    Thanks in advance
    Frank
    Jan 2005
    konstanz, germany
    Exclamation Hi ...
    I think that's a problem of two different subnets one subnet for PC <--> Router <--> WLHDD and if I'm right there is a second subnet WLHDD <--> D-Box ...
    There must be a possibility of IP forwarding ... connecting those two subnets ... but I'm not sure if it is possible to redirect WLAN -> wired subnet or teh other direction ...
    Am I right?
    Good luck
    Martin
