Two choices:
- You have to be more familiar with diff/patch utils
- checkout stable build (add -r XXXX switch to svn cmdline)
P.S. Take a look at r3877
Hi all,
I am trying to compile a custom firmware (I want to add some stuff that I will be writing for access to usb serial for home automation).
The build server is centos 6.
I followed on all the steps from the custom firmware compilation tutorial from code.google.com
There was one problem regarding location of Kernel files which I fixed by adding another "linux" to path.
Now the compilation fails with the following message:
LPRng/010-gcc-warnings.patch
Can not apply LPRng/010-gcc-warnings.patch cleanly
Any ideas?
Two choices:
Thanks for your help.
The firmware is compiling now.
There are lots of complaints about missing version information, I suppose I can ignore this right?
