Use firmware restoration tool from the CD.
Hi everybody,
I was using firmware 1.9.2.7-3c without any problem until today. I tried to upgrade with the new version 1.9.2.7-6b. While the router was saving the firmwaren the power led started to blink and nothing can stop it now. I'm afraid the flash memory contains now a corrupted firmware...
Does someone have an idea of anything to do to restore a correct version.
Thanks.
Than you Oleg for your reply.
The restoration tools finally worked properly. This is a great feature asus propose there!
Thank you again.
