Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 62
Thread: [Announce] New EntWare package repository for 1.9.2.7-rtn firmware
  1. #46
    ryzhov_al
    something is broken around pyload and python (update to python 2.7.3rc2 earlier this month)
    when I'm acessing the pyload webif I get a segmentation fault.
    the guys from the pyload IRC told me to reinstall python.
    What should we do? Can sb. confirm the segfault?
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  2. #47
    Quote Originally Posted by !gm View Post
    Yes. A python binaries in the OpenWRT was updated and all those precompiled *.pyc-files now is not compatible with a new one.
    An easiest way to fix it is:
    1. Remove pyload and all dependencies,
    2. Manually erase all *.pyc-files from /opt/lib/pyhon,
    3. Install pyload again.
    *.pyc-files will be recompiled again after a first pyload start. This is a generic fix to a similar problem with any python-driven packages: dropbox-python and others.
  3. #48
    hm I removes all the python stuff (and pyload, of corse)
    then did a rm -r /opt/lib/python2.*
    reinstalled pyload again (with python, djangio etc.)
    pyload -s all OK
    but segfault again
    edit: after cleaning /opt/share/python too, and removing python from /opt/bin (dunnow why it wasn't removed via opkg....)
    I now have the situation (after opkg install python ), that there is nothing python related in /opt/bin (is that missing in the ipk?) so that the python pyLoadcore symlink can not be executed
    edit2: ahhh python-mini provides the bin, python the lib
    edit3: ok, even after removing python-mini as well and reinstalling/reconfiguring pyload i get the segfault
    thought you pointed me in the right direction - good night
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  4. #49
    today I tried it again and got it working after
    rm -r /opt/etc/pyload/tmp
    mkdir /opt/etc/pyload/tmp
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  5. #50
    Hallo together!
    Maybe a stupid question, but will the startup-etc-entries now work with entware with the new officially released 4051?
    I mean: Can I simply follow the wengi-tut with exchange of the installation routine (entware instead of ipkg) and exchange of the ipkg commands to the respective opkg commands?
    Or will the other stuff (paths for post-boot etc.) have to be changed, too?
    Thanks!
  6. #51
    Quote Originally Posted by pheidrias View Post
    Hallo together!
    Yes!
    and the start-stop scripts will work too (you may modify some of them because of new features, or a different option-syntax, but they are not (yet) included in the packages of the new repository
    remember the new mountpoints in kernel 2.6 (/dev/discs/disc[x]/part[x]) in fstab
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  7. #52
    Re: [Announce] New OpenWRT package repository for 1.9.2.7-rtn firmware
    I am unable to install uclibc-opt
    then opkg not working.
    Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/uclibc-opt_0.9.32-1_entware.ipk ...
    Connecting to wl500g-repo.googlecode.com (209.85.175.82:80)
    uclibc-opt_0.9.32-1_ 100% |*******************************|   928  --:--:-- ETA
    Done.
    Unpacking uclibc-opt...Done.
    Configuring uclibc-opt...Updating /opt/etc/ld.so.cache
    Illegal instruction
    Done.
    Downloading http://wl500g-repo.googlecode.com/svn/ipkg/openwrt/opkg_618-2_entware.ipk ...
    opkg_618-2_entware.i 100% |*******************************| 61010  00:00:00 ETA
    Done.
    Unpacking opkg...Done.
    Configuring opkg...Done.
    [admin@ARiTU /tmp]$ opkg update
    -sh: opkg: not found
    [admin@ARiTU /tmp]$
  8. #53
    I'm sorry, i can not reproduce your problem.
    Tested on RT-N16 with 1.9.2.7-rtn-r4051 and latest updates. Everything is fine.
  9. #54
    Entware digest
    Repo updated to last OpenWRT trunk (r32017) last night.
    • Bind, darkstat, htop, psmisc, python, samba36, transmission and some other packages updated.
    • All services now includes start\stop scripts.
    • ~40 binaries wrong linkage fixed. It's for RT-N56 users.
    • Newbiefan and MercuryV joined to Entware team. Thanks for your contribution guys!
  10. #55
    Great job guys, you have added many new packages. I want to ask if you could still add the mercurial (hg) and mutt or mailx? Thanks.
  11. #56
    testing minidlna 1.0.25
    I try to compile the new minidlna-version with latest entware-buildroot (not successful yet).
    I think the problem is something ffmpeg-related.
    Anyone a solution?
    http://pastebin.com/7fg9kYH2
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  12. #57
    Anyone a solution?
    Minidlna authors are bit screwed with libavformat features detection.
    Place this patch to ./openwrt_trunk/feeds/package/multimedia/minidlna/patches folder before compilation.
  13. #58
    with that change it compiles well!
    I test the package for a about a week, so that you can safely bump the version for the main-entware repo. I doubt there are no problems.
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  14. #59
    minidlna is bumpable
    OK, I watched some movies recently - different formats and with subs. No problems so far. Its ready for the entware-repository
    1.0.25 - Released 13-July-2012 --------------------------------
    - Fix a couple crash bugs on malformed WAV files.
    - Forcibly tweak the model number for Xbox360 clients, or they might ignore us.
    - Enable all network interfaces by default if none were specified.
    - Add flag to force downscaled thumbnails rather than using embedded ones.
    - Add DirecTV client detection, and fix image resolution issue.
    - Add support for the latest ffmpeg/libav library versions.
    - Fix a potential crash on requests for a resize of a non-existent image.
    - Make DeviceID checking more permissive for Sagem Radio.
    pyload 0.4.9
    minidlna 1.1.2
    samba 3.6.5
    openvpn 2.3.10
  15. #60
    Repo updated
    • 25volt - 1.0.5. UPS APC & Powercom
    • angband - 3.5.0,
    • asterisk18 - 1.8.25.0,
    • bfgminer - 3.10.0,
    • bip - 0.8.9,
    • bird до 1.4.0
    • crawl до 0.13.1,
    • dovecot до 2.2.8,
    • dropbox-uploader до 0.13,
    • duo_unix до 1.9.6,
    • erlang-asn1 до 2.0.3,
    • erlang-compiler до 4.9.3,
    • erlang-crypto до 3.1,
    • erlang-hipe до 3.10.2.1,
    • erlang-inets до 5.9.6,
    • erlang-mnesia до 4.10,
    • erlang до R16B02,
    • erlang-runtime-tools до 1.8.12,
    • erlang-snmp до 4.24.2,
    • erlang-ssh до 2.1.8,
    • erlang-ssl до 5.3.1,
    • erlang-syntax-tools до 1.6.11,
    • git до 1.8.4.4,
    • gnuchess до 6.1.1,
    • hplip до 3.14.1,
    • idle3-tools 0.9.3-r21,
    • imagemagick до 3.14.1,
    • imapfilter до 2.5.6,
    • inetutils до 1.9.2,
    • kexec-tools до 2.0.4,
    • mosh до 1.2.4a-20140108,
    • mp707 до 0.1.0,
    • n2n до 2.1.0-r7223,
    • nfs-kernel-server до 1.2.9,
    • nginx до 1.4.4,
    • nzbget до 12.0,
    • nyancat до 1.2.2,
    • objdump до 2.22-6,
    • oscam до 1.20-r9415,
    • pbzip2 до 1.1.8,
    • php5 до 5.4.23,
    • ptokax до 0.5.0.1,
    • python-chardet до 2.2.1,
    • python-cups до 1.9.66,
    • python-dropbox до 2.0.0,
    • python-gevent до 1.0,
    • python-greenlet до 0.4.2,
    • python-requests до 2.2.0,
    • python-skydrive до 13.12.1,
    • spdylay до 1.2.2,
    • splix 2.0.0,
    • tty-solitaire 0.0.0,
    • umurmur - 0.2.14,
    • weave-minimal - 1.5,
    • whois - 5.1.1,
    • xupnpd - 395,
    • znc - 1.2.
    * https://code.google.com/p/wl500g-repo/issues/list
    * http://wl500g.info/showthread.php?t=28036
  1. Entware - новый репозиторий для роутеров Asus (MIPS)
    Last Post: 04-01-2021, 22:16
  2. Установка rTorrent + ruTorrent из репозитория Entware
    Last Post: 11-02-2016, 15:29
  3. Samba 3.6 EntWare - установка и настройка
    By voidshah in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 02-12-2014, 11:37
  4. Optware oder Entware?
    Last Post: 20-12-2012, 17:51
  5. Torrentflux mod, controls Transmission - can someone package it?
    By nant15 in forum WL-500g Custom Development
    Last Post: 14-11-2006, 20:49
