Results 31 to 45 of 84
Thread: RRDTool Traffic Graph Tutorial - Extremely easy to follow !
    did you remember to mount a disk on /opt ?
    To me it looks like you are trying to write directly to the flash, which isnt supported in Olegs firmware (that part of the flash anyway).
    macsat
    I als got the "/opt/usr/bin" (it doesn't exist) issue but I changed the path to /opt/bin and changed the line in the config
    But when I try to acces my-ip-/rrd is says: file not found
    ps aux only shows that cron has started
    1 root 660 S /sbin/init
    2 root SW [keventd]
    3 root SWN [ksoftirqd_CPU0]
    4 root SW [kswapd]
    5 root SW [bdflush]
    6 root SW [kupdated]
    7 root SW [mtdblockd]
    61 root 320 S telnetd
    66 root 376 S httpd vlan1
    70 root 388 S syslogd -m 0 -O /tmp/syslog.log -S -l 7
    71 root 340 S klogd
    73 nobody 496 S dnsmasq
    74 root 460 S snmpd -c /tmp/snmpd.conf
    81 root SW [khubd]
    90 root 276 S lpd
    92 root 260 S p9100d -f /dev/usb/lp0 0
    95 root 344 S waveservermain
    97 root 344 S rcamdmain
    101 root SW [usb-storage-0]
    102 root SW [scsi_eh_0]
    107 root 320 S infosvr br0
    108 root 468 S watchdog
    111 root 344 S ntp
    122 root SW [kjournald]
    136 root 432 S udhcpc -i vlan1 -p /var/run/udhcpc0.pid -s /tmp/udhcp
    140 root 408 S /opt/sbin/cron
    154 root 568 S upnp -D -L br0 -W vlan1
    198 root 544 S -sh
    211 root 392 R ps aux
    BTW...thttpd config was saying port: 8080 instead of 81
    with port 81 or 8080 i got http://192.168.1.254/rrd "file not found"
    (btw rrdtool.log is empty)
    What to check to make it work?
    May 2006
    Netherlands
    My problem still is the same. THHTPD seems to shutdown on its own Where is the logfile ? Has anyone else suffered from this fenomenon?
    I began from scratch, installed SSH, VSFTPD, THTTPD but still the problem stays
    My current collection:
    WL-500gX (original firmware), WL-500gX (Oleg 1.9.2.7-7g), WL-500gX (Oleg 1.9.2.7-8), WL-700gE (Asus 2.0.0.7)
    OK, i finally got it working. I just copied the script in /opt/bin i.s.o. /opt/usr/bin.
    Quote Originally Posted by netvista View Post
    I have one more question though. Why is my WAN graph always at a steady 222 bytes...
    It doesn't matter if download a lot or not....it's always 220 bytes...strange. Also i tested the LAN & WLAN graph bij transferring a big file from my pc (wired) to my laptop (wireless).
    The LAN graph shows a big peak for INCOMING traffic and the WLAN graph shows a big peak for OUTGOING traffic... I think it should be the other way around... do i interpret it incorrectly?
    Thanks in advance
    nice tutorial. working perfectly. thanks!
    Thanks for the tutorial, works fine.
    Only problem I had was with the graph creation, since I currently don't have a wireless client the data is 0 and this apparently caused the generation to hang.
    Jun 2005
    The Netherlands, Haarlem
    I have some problems with rrdrun.sh, it wont execute ok so-ever
    it wont create png files
    root@Devil-Strike cron.5mins]$ ./rrdrun.sh
    /bin/sh: Can't open
    dont know what to do know.
    have you made it executable? (chmod +x)
    For the record and history purposes...the link tot the page on the router in the tutorial isn't quite right...must be
    http://192.168.1.254:8080/rrd/
    Feb 2007
    Bangkok Thailand
    Smile Nice program
    Hi.
    Thank you for good script to view the traffic.
    I have one question.
    How to log every 2 second? like this http://www.polarcloud.com/v/scbwm.htm
    Thank you.
    I'm having this problem:
    Tue Mar 6 11:30:01 GMT 2007
    WAN Interface: vlan1
    LAN Interface: vlan0
    WLAN Interface: eth1
    WAN -> in: 2057306 out: 737424
    LAN -> in: 0 out: 294284
    WLAN -> in: 0 out: 0
    /opt/usr/bin/rrdtool.sh: /opt/usr/bin/rrdtool.sh: 136: rrdupdate: not found
    /opt/usr/bin/rrdtool.sh: /opt/usr/bin/rrdtool.sh: 137: rrdupdate: not found
    /opt/usr/bin/rrdtool.sh: /opt/usr/bin/rrdtool.sh: 138: rrdupdate: not found
    Daily Graphs created.....
    /opt/usr/bin/rrdtool.sh: /opt/usr/bin/rrdtool.sh: 172: rrdtool: not found
    mv: unable to rename `/opt/share/www/rrd//wanday.png.new': No such file or dire$
    mv: unable to rename `/opt/share/www/rrd//landay.png.new': No such file or dire$
    mv: unable to rename `/opt/share/www/rrd//wlanday.png.new': No such file or dir$
    And the graphs don't get created...
    Any clue on this?
    Thanks...
    [edit:] - I guess I may have found the problem: there are compatibility issues with the latest uClibc in -7f... This only works in -7g... damm...
  13. Is it possible to add another graph which shows the load of the router?
    I think that I've installed, because I can load the page, but It didn't show any graph, Will I need to w8 a day to see it? or is the admin root problem? I'm running wl500gP, if that's the problem How do I solve it?
    I've admin in crontab...
    solved with chmod +x rrdtool
    Angry
    One thing just kills me. All router power goes to make those crapy lines and i havent installed nothing except samba, wwwphp, dropbear, nano. Refresh goes every 5 min and still :/
    If that wont help i will say byebye to rrdtool.sh and find other way to generate stats
    EDIT:
    imo txt stat version would be nice
  1. Tutorial, hoe bekijk ik mijn webcam vanaf het internet
    By carl in forum Dutch Discussion - Nederlands
    Last Post: 29-06-2009, 15:37
  2. samba and oleg tutorial
    By ddieter in forum WL-500g Q&A
    Last Post: 15-02-2008, 13:08
  3. Easy-to use cron-system.
    By macsat in forum WL-500g/WL-500gx Tutorials
    Last Post: 29-05-2007, 21:18
  4. Replies: 0
    Last Post: 17-09-2005, 18:34
  5. How can I log the traffic ?
    By exilist in forum WL-500g Q&A
    Last Post: 06-06-2004, 09:31
