My soundcards seem to be recognized correctly, but all that comes out is just silence.
I already killed waveserver&waveservermain
I'm using the very latest Oleg firmware (CR8).
When i type " madplay rastaman.mp3 -o /dev/sound/dsp -v " it produces no errors, but it decodes way too fast. And, yes, there is no sound
I installed Smixer (but couldn't handle it) and Lmixer. With Lmixer, I set PCM Volume is set to 100.
The Souncards i use are: (I tried one after the other)
1) Griffin Imic: - dmesg says:
rate 4000
usbaudio: valid input sample rate 48000
usbaudio: valid input sample rate 44100
usbaudio: valid input sample rate 32000
usbaudio: valid input sample rate 24000
usbaudio: valid input sample rate 22050
usbaudio: valid input sample rate 16000
usbaudio: valid input sample rate 12000
usbaudio: valid input sample rate 11025
usbaudio: valid input sample rate 8000
usbaudio: valid input sample rate 6000
usbaudio: valid input sample rate 5512
usbaudio: device 8 interface 2 altsetting 1: format 0x00000040 sratelo 4000 sratehi 48000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 2 channels 2 framesize 1 configured
usbaudio: valid input sample rate 4000
usbaudio: device 8 interface 2 altsetting 2: format 0x01000040 sratelo 4000 sratehi 48000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 3 channels 1 framesize 2 configured
usbaudio: device 8 interface 2 altsetting 3: format 0x00000010 sratelo 4000 sratehi 48000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 4 channels 2 framesize 2 configured
usbaudio: device 8 interface 2 altsetting 4: format 0x01000010 sratelo 4000 sratehi 48000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 5 channels 1 framesize 3 configured
usbaudio: device 8 interface 2 altsetting 5: format 0x00000800 sratelo 4000 sratehi 48000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 6 channels 2 framesize 3 configured
usbaudio: device 8 interface 2 altsetting 6: format 0x01000800 sratelo 4000 sratehi 48000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 7 channels 1 framesize 2 configured
usbaudio: device 8 interface 2 altsetting 7: format 0x00000010 sratelo 4000 sratehi 16000 attributes 0x01
usbaudio: device 8 interface 2 altsetting 8 channels 2 framesize 2 configured
usbaudio: device 8 interface 2 altsetting 8: format 0x01000010 sratelo 4000 sratehi 16000 attributes 0x01
usbaudio: device 8 interface 1 altsetting 0 does not have an endpoint
usbaudio: device 8 interface 1 altsetting 1 channels 1 framesize 1 configured
usbaudio: valid output sample rate 4990
usbaudio: valid output sample rate 48010
usbaudio: device 8 interface 1 altsetting 1: format 0x00000040 sratelo 4990 sratehi 48010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 2 channels 2 framesize 1 configured
usbaudio: device 8 interface 1 altsetting 2: format 0x01000040 sratelo 4990 sratehi 48010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 3 channels 1 framesize 2 configured
usbaudio: device 8 interface 1 altsetting 3: format 0x00000010 sratelo 4990 sratehi 48010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 4 channels 2 framesize 2 configured
usbaudio: device 8 interface 1 altsetting 4: format 0x01000010 sratelo 4990 sratehi 48010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 5 channels 1 framesize 3 configured
usbaudio: device 8 interface 1 altsetting 5: format 0x00000800 sratelo 4990 sratehi 48010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 6 channels 2 framesize 3 configured
usbaudio: device 8 interface 1 altsetting 6: format 0x01000800 sratelo 4990 sratehi 48010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 7 channels 1 framesize 2 configured
usbaudio: valid output sample rate 18010
usbaudio: device 8 interface 1 altsetting 7: format 0x00000010 sratelo 4990 sratehi 18010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 8 channels 2 framesize 2 configured
usbaudio: device 8 interface 1 altsetting 8: format 0x01000010 sratelo 4990 sratehi 18010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 9 channels 1 framesize 2 configured
usbaudio: valid output sample rate 26010
usbaudio: device 8 interface 1 altsetting 9: format 0x00000010 sratelo 4990 sratehi 26010 attributes 0x00
usbaudio: device 8 interface 1 altsetting 10 channels 2 framesize 2 configured
usbaudio: device 8 interface 1 altsetting 10: format 0x01000010 sratelo 4990 sratehi 26010 attributes 0x00
usbaudio: registered dsp 14,3
usbaudio: constructing mixer for Terminal 3 type 0x0601
usbaudio: registered mixer 14,0
usbaudio: constructing mixer for Terminal 8 type 0x0101
usbaudio: registered mixer 14,16
usb_audio_parsecontrol: usb_audio_state at 81ce5460
2) 13€- Soundcard from Speedlink (bought at "Saturn)
I can't post a second dmesg-output here, but there is no sound, neither.
This Soundcard has a led which should blink while playing sound (tested on my macbook) - but it doesn't
I'm not that Linux nerd - so maybe it's just a silly mistake somewhere?
