Results 1 to 9 of 9
Thread: Problem with Printer WL500G
    Hi Guys,
    I bought the wl500g unit a few days ago... I got it all set up and all, updated to Oleg's latest firmware 1.9.2.7 cr 6 I believe it's called...
    However, after updating to this firmware the printer setup vanished from the usb devices menu and I can't seem to find it anywhere... when I plug my printer the router does see it as active and connected however i can't print.
    I follow the lpr printing setup guid for lpr printing and it just doesn't work.
    I tried to connect the printer via usb. should I try lpt?
    My printer is xerox phaser 3130
    Anything I'm missing here?
    All help will be more then appriciated!
    Max.
    Did you follow Olegs guide on printing ?
    http://oleg.wl500g.info/printing/
    Explains it step4step.
    macsat
    Quote Originally Posted by maxshifrin
    There is no special printer setup page in ANY firmware version. The only traces for printer are Status page and Internet firewall basic config.
    I did use Olegs guide but it didn't work
    I used Olegs guide and it didn't work.
    The router does identify the printer but it just doesn't print.
    An interesting note on this is that the router doesn't respond to telnet on port 9100 and 9101 from inside the network so i'm wondering how is it supposed to print?
    Here's what the router log says about the printer:
    Jul 6 20:39:45 kernel: hub.c: new USB device 00:04.0-1, assigned address 2
    Jul 6 20:39:45 kernel: printer.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x04E8 pid 0x323B
    Jul 6 20:39:45 kernel: printer.c: usblp0 Device ID string [87]='MFG:Xerox;CMD:PCL5E,PCL6;MDL:Phaser 3130;CLS:PRINTER;MODE:PCL;STATUS:IDLE;CODE:10003;'
    Jul 6 20:40:16 kernel: printer.c: usblp0 Device ID string [87/max 1552]='MFG:Xerox;CMD:PCL5E,PCL6;MDL:Phaser 3130;CLS:PRINTER;MODE:PCL;STATUS:IDLE;CODE:10001;'
    Jul 6 20:40:16 kernel: printer.c: Parsing USBLPID...
    Jul 6 20:40:32 kernel: printer.c: usblp0 Device ID string [87/max 1552]='MFG:Xerox;CMD:PCL5E,PCL6;MDL:Phaser 3130;CLS:PRINTER;MODE:PCL;STATUS:IDLE;CODE:10001;'
    Jul 6 20:40:32 kernel: printer.c: Parsing USBLPID...
    Jul 6 20:45:09 kernel: printer.c: usblp0 Device ID string [87/max 1552]='MFG:Xerox;CMD:PCL5E,PCL6;MDL:Phaser 3130;CLS:PRINTER;MODE:PCL;STATUS:IDLE;CODE:10001;'
    Jul 6 20:45:09 kernel: printer.c: Parsing USBLPID...
    Ideas?
    Max.
    P.S.
    A country timezone which is missing in the router is Israel
    reflashed and it worked
    I burned the firmware all over again and it works fine now... go figure
    Hesitate - printer issue
    Hi again!
    Now I got Oleg and working USB ports.
    So I'm going to buy cheap printer. I'm thinking about this two:
    Xerox Phaser 3117. Printer has been reported as WORKING on Asus500gDeluxe by tonych and by St3f
    So I assume it will work on Asus500gP too? Please confirm.
    Second is Samsung 2010R. Printer has build-in processor (150MHz) and 8MB RAM. I wonder if it will work with WL500gP and Oleg firmware?
    Thanks in advance.
    Nov 2007
    EU's border...
    I can recommend you also Lexmark E120.
    Is cheap enough and IS WORKING very fine on WL500gP.
    Thumbs up
    Theoretically, every USB printer should work with the RAW option, since the data is just pushed through the router.
    It works for my Canon Laserbase MF3110 multifunctional, which has no Linux support whatsoever (printer part only - not scanner).
    This is one BIG difference between Olegs and the stock firmware in my opinion.
    Greetings,
    Marius
    Feb 2007
    Well, I can confirm that xerox 3117 works fine through wl500gP using Oleg's fw raw 9100-port printing (default way of printing in Oleg's fws).
    Unfortunately, it is not completely true statement, as some (luckily minority) of USB printers require to have some firmware to be uploaded before printing. Some HPs (probably, 1018 and 1020) require it.
    P.S. actually xerox 3117 is manufactured by samsung (its equivivalent is samsung 1610 or 1615).
  1. Mac : problem for sharing my printer (epson 740) !
    By Buandflu in forum WL-500g Q&A
    Last Post: 04-02-2005, 19:37
  2. MOVED: problem w/ KYOCERA PRINTER :(
    By epanda in forum WL-500g Q&A
    Last Post: 18-11-2004, 11:30
  3. printer problem solved
    By Kronos in forum WL-500g Q&A
    Last Post: 15-11-2004, 23:30
  4. Printer sharing problem
    By Fenni in forum WL-500g Q&A
    Last Post: 01-11-2004, 02:42
