Perhaps guide should be updated. Works fine with built-in config:
P.S. Why don't you use default config?Code:[global] interfaces = br0 bind interfaces only = yes workgroup = WORKGROUP guest account = nobody security = share browseable = yes guest ok = yes guest only = yes log level = 1 max log size = 100 encrypt passwords = no preserve case = yes short preserve case = yes [share] path = /tmp/harddisk [share$] path = /tmp/harddisk writable = yes force user = root browseable = no
