Thanks for the reply.. i'll try that later.Originally posted by Wisi
try to insert the key instead of a passphrase
as i wrote in howto this helped me to get cards workin with the same problem you have.
with passphrase i got connection, everything seems to be correct but no data, dhcp or something else could be transferred.
after i took the same passphrase but inserted the key directly on the windows xp client everything worked as expected
i had this problem only with wep 128 bit encryption
wpa-psk worked with passphrase without a problem
Just to make sure: Did it work when you enabled the wireless firewall and dhcp server? (your wireless adapter should have an ip address in the 192.168.2.x range)
thanks,
Pascal
