Hello there
I have a box which I use as internet gateway and I need a very specific NAT rule which I can't seem to be able to grasp.
There is a very restrictive filter at my workplace which only allows outgoing packets on port 80 and pretty much nothing else (yep, not even FTP). I want packets from source X (my work IP) to port 80 on my box to be handled by the SSH server.
I've tried the following command:
iptables --table nat -I VSERVER -s X/32 -p tcp -j DNAT --dport 80 --to-destination 192.168.1.1:22
and also
iptables --table nat -I VSERVER -s X/32 -p tcp -j DNAT --dport 80 --to-destination 127.0.0.1:22
None of them seem to work. It works if I use any other port except port 80 (so if I put 11111 it works). It doesn't work if I remove the source address or if I forward it from another port...
What else can I do?
