reset to defaults and read faq.
I can successfully flash Oleg's firmware, but the usual admin / admin login doesn't work. What do I have to do?
Edit: I'm using version 1.9.2.7-6a
thank you very much, i did just search the forum and read through your site, but i haven't seen the faq, sorry.
I have two more questions:
- I don't see any options for setting shares on the internal HD*
- I can only access the wl-hdd using his ip, not his hostname
What am I doing wrong?
*Edit: my drive is formatted in FAT32 Filesystem, is this the problem?
the hostname should work IF you set it right in the websetupOriginally Posted by aflo
the shares is just right, you are not using an WL-HDD firmware so setting up Samba Demo mode enables for example \\WL-HDD\share and \\WL-HDD\share$
I did set it right. Now I've switched back to the official firmware and it works again.
Which is the best way to get my WL-HDD doing all what the official firmware can + printserver + hd spindown after reasonable time?
No usernameCode:I can successfully flash Oleg's firmware, but the usual admin / admin login doesn't work. What do I have to do? Edit: I'm using version 1.9.2.7-6a
Password: Admin
FAQ look here
but I want to share my internal HD, not an USB one.Originally Posted by Antiloop
That would be no problem just take a look at this tutorialbut I want to share my internal HD, not an USB one.
It's for setting up samba, harddisk and all that stuff.
My Asus Collection (just starting):
wl-hdd (1.9.2.7-6a, with HUB, USB-HDD, CARDREADER, CAM) Asus A3878GLP Notebook 15" Centrino 2,0 , 1024MB, 80GB, WLAN built-in, DVD+-RW
