No way with ASUS firmware. This is supported by custom firmware only.
I have to connect with PPPoE for internet, but I am also connected to the LAN of my apartment building. When I use PPPoE I cannot get access to the LAN. How can I get connected to both at the same time?
Which custom firmware do I need? I have already installed your firmware 'v1.9.2.7 CR5a [Oleg]'Originally Posted by Oleg
-5a is fine, you just need to enter your IP address/mask (the one assigned to you by this building ISP) to the WAN IP Address field.
Thanks Oleg for you quick help. Everything works great now, except MSN 7.0 file transfers, but that's a different problem.
I am wondering if it is somehow possible to have more than 2 DNS servers configured. At the moment I use one entry for the LAN and one for the PPPoE DNS server. For fault tolerance it would be preferable to have two DNS servers for each. Is there any way to add four DNS servers into the configuration menu? Thanks in advance.
