In the sources. The problem was that you got "no such device" in the log during the printing attempt, while the printer is detected and displayed on the status page.Originally Posted by FauDrei
(Where) can we read more about it Oleg?
It seems that 6b work's very well..Originally Posted by Oleg
I will test samba and printer tomorrow..
Home Page
Marco Sousa from PORTUGAL
Its not possivel to include in AP Mode: Client mode ?
This are the best thing, in wl that are missing...
Lot of work???
Home Page
It's already there: Wireless | Advanced | Extended mode > Ethernet Bridge.Originally Posted by int
Im now using 6b, and it seems quite stable... the auto negotiation in "wan connection speed" its working good (back again, finnally :P ).
I will continue to test after 72h of working and post my conclusions.
After some use of the 6a.3 ( ~72hours ) the firmware it seems stable and no resets, reboots or problems from services.
Once again just to remember my test's are using the WL500g with 1 connection in LAN and 3 WLAN connection WPA-PSK/ AES+TKIP ( 2 AES broadcom chip 802.11g and one 1 TKIP intel 802.11b ), with FTP server, DYNDNS and a print service port 9101.
Using WL500g - firmware 1.9.2.7-7e [from Oleg's]
Thank you Oleg for this fix, works fine now with the auto negotiation enabled.Originally Posted by Oleg
You are a star!
My WL500g its been runing with a quite good stability more than 72H On and going up!
Thanks for developing this firmware since the begining
Hi Oleg!
I use the new v1.9.2.7 CR6b firmware a few days. It's very stable, no restart, no slow down on auto negotiation mode, but the connection time is invalid in the future too.
"Jul 3 17:10:46 pppd[76]: Connect time 18673390.5 minutes."
Zitev
Hi
I can't make samba works on my WL500g...
I see other threats but its diferent on this FW...
I put my harddisk on WL, and i can see the files on /tmp/harddisk/
but what i have to do to make samba works fine with public read/write acess?
Home Page
Hm... Have you read my answer?Originally Posted by Zitev
http://wl500g.info/showpost.php?p=17766&postcount=63
Have you assigned LAN Hostname to your router and enabled samba? Yes, samba is changed in the 1.9.2.7-6, but it's still works fine. For r/w access use share$Originally Posted by int
i already enable samba, and put LAN as my hostname, and don't work i see that smb.conf was not create...???
Home Page
[QUOTE=Oleg]Hm... Have you read my answer?
Ohhh...I missed your answer, sorry...THX!
Zitev
After changing from 1.9.2.7-6.3 to 1.9.2.7.6b after a few days without any problems, I am having disconnections again. Are there any differences between those 2 firmwares?
Please take a look at my logfile.
THX
