Page 17 of 17 FirstFirst ... 7151617
Results 241 to 242 of 242
Thread: Firmware v1.9.2.7 CR6, updated to CR6a ... now CR6b [Oleg]
  1. #241
    Quote Originally Posted by jjason
    username ########
    password ########
    authserver dce-server
    authdomain nsw.bigpond.net.au
    localport 5050
    logging syslog
    debuglevel 2
    minheartbeatinterval 60
    maxheartbeatinterval 420
    #connectedprog bpa_connect
    #disconnectedprog bpa_disconnect
    This file does not seem to be automatically generated by firmware. Which value you've specified for Heartbeat server?
    Also, I need nvram values for wan_heartbeat_x, wan0_domain, wan0_gateway
  2. #242
    The bpalogin.conf file I posted earlier is the one I created manually. Here is the original as generated by the firmware:
    username xxxxxxxx
    password xxxxxxxx
    authserver 61.9.192.13
    localport 5050
    logging syslog
    debuglevel 0
    The nvram values are:
    wan_heartbeat_x=61.9.192.13
    wan0_heartbeat_x=
    wan0_domain=nsw.bigpond.net.au
    wan0_gateway_t=
    wan0_gateway=<IP address of my WAN gateway>
    Incidentally, I've done some more testing and there is a very simple solution to this whole issue. Simply appending the BigPond domain (<state>.bigpond.net.au) to the resolv.conf file using the post-boot script allows bpalogin to register the correct address for the heartbeat server. This simple approach works because bpalogin actually executes a few moments after the post-boot script (not before as I was led to believe).
    In other words, no changes to bpaconfig.conf are needed, and no need to setup the post-boot file to kill the bpalogin process on startup and then restart with the new config file. All that the post-boot file needs to do is append a line to the resolv.conf file with the BigPond domain.
  1. Firmware v1.9.2.7 CR5, updated: v1.9.2.7 CR5a [Oleg]
    Last Post: 18-06-2005, 12:07
  2. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 10:01
  3. Firmware v1.7.5.6 CR3 [Oleg]
    Last Post: 28-07-2004, 21:11
  4. Firmware v1.7.5.6 CR4 [Oleg]
    Last Post: 30-05-2004, 15:56
    Last Post: 07-04-2004, 17:22
