Here it is:
Jan 1 01:00:05 syslogd started: BusyBox v1.00 (2005.05.11-18:29+0000)
Jan 1 01:00:05 dnsmasq[58]: started, version 2.17 cachesize 150
Jan 1 01:00:05 dnsmasq[58]: DHCP, IP range 192.168.1.2 -- 192.168.1.7, lease time 24h
Jan 1 01:00:05 dnsmasq[58]: DHCP, /tmp/dnsmasq.log will be written every 28800s
Jan 1 01:00:05 kernel: number of CFI chips: 1
Jan 1 01:00:05 kernel: Flash device: 0x400000 at 0x1c000000
Jan 1 01:00:05 kernel: Physically mapped flash: squashfs filesystem found at block 941
Jan 1 01:00:05 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 01:00:05 kernel: 0x00000000-0x00040000 : "pmon"
Jan 1 01:00:05 kernel: 0x00040000-0x003e0000 : "linux"
Jan 1 01:00:05 kernel: 0x000eb5b4-0x003e0000 : "rootfs"
Jan 1 01:00:05 kernel: 0x003f0000-0x00400000 : "nvram"
Jan 1 01:00:05 kernel: 0x003e0000-0x003f0000 : "config"
Jan 1 01:00:05 kernel: sflash: found no supported devices
Jan 1 01:00:05 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 01:00:05 dnsmasq[58]: read /etc/hosts - 5 addresses
Jan 1 01:00:05 dnsmasq[58]: read /etc/ethers - 2 addresses
Jan 1 01:00:05 dnsmasq[58]: reading /tmp/resolv.conf
Jan 1 01:00:05 kernel: IP Protocols: ICMP, UDP, TCP
Jan 1 01:00:05 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 01:00:05 kernel: TCP: Hash tables configured (established 2048 bind 4096)
Jan 1 01:00:05 kernel: ip_conntrack version 2.1 (256 buckets, 2048 max) - 344 bytes per conntrack
Jan 1 01:00:05 kernel: ip_conntrack_pptp version 1.9 loaded
Jan 1 01:00:05 kernel: ip_nat_pptp version 1.5 loaded
Jan 1 01:00:05 kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 1 01:00:05 kernel: ipt_time loading
Jan 1 01:00:05 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 01:00:05 kernel: IPv6 v0.8 for NET4.0
Jan 1 01:00:05 kernel: IPv6 over IPv4 tunneling driver
Jan 1 01:00:05 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 01:00:05 kernel: 802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
Jan 1 01:00:05 kernel: All bugs added by David S. Miller <davem@redhat.com>
Jan 1 01:00:05 kernel: FAT: bogus logical sector size 64512
Jan 1 01:00:05 kernel: NTFS: Unable to set blocksize 512.
Jan 1 01:00:05 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 01:00:05 kernel: Mounted devfs on /dev
Jan 1 01:00:05 kernel: Freeing unused kernel memory: 72k freed
Jan 1 01:00:05 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 01:00:05 kernel: eth0: Broadcom BCM47xx 10/100 Mbps Ethernet Controller 3.90.7.0
Jan 1 01:00:05 kernel: PCI: Enabling device 01:03.0 (0004 -> 0006)
Jan 1 01:00:05 kernel: ontroller 3.90.23.0
Jan 1 01:00:05 kernel: device eth1 entered promiscuous mode
Jan 1 01:00:05 kernel: eth0.1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 01:00:05 kernel: eth0.1: add 33:33:ff:9f:97:48 mcast address to master interface
Jan 1 01:00:05 kernel: eth0.1: dev_set_promiscuity(master, 1)
Jan 1 01:00:05 kernel: device eth0 entered promiscuous mode
Jan 1 01:00:05 kernel: device eth0.1 entered promiscuous mode
Jan 1 01:00:05 kernel: br0: port 2(eth0.1) entering listening state
Jan 1 01:00:05 kernel: br0: port 1(eth1) entering listening state
Jan 1 01:00:05 kernel: br0: port 2(eth0.1) entering learning state
Jan 1 01:00:05 kernel: br0: port 2(eth0.1) entering forwarding state
Jan 1 01:00:05 kernel: br0: topology change detected, propagating
Jan 1 01:00:05 kernel: br0: port 1(eth1) entering learning state
Jan 1 01:00:05 kernel: br0: port 1(eth1) entering forwarding state
Jan 1 01:00:05 kernel: usb.c: registered new driver usbdevfs
Jan 1 01:00:05 kernel: usb.c: registered new driver hub
Jan 1 01:00:05 kernel: usb-uhci.c: $Revision: 1.275 $ time 21:43:09 Apr 20 2005
Jan 1 01:00:05 kernel: usb-uhci.c: High bandwidth mode enabled
Jan 1 01:00:05 kernel: PCI: Enabling device 01:02.0 (0000 -> 0001)
Jan 1 01:00:05 kernel: usb-uhci.c: USB UHCI at I/O 0x100, IRQ 2
Jan 1 01:00:05 kernel: usb-uhci.c: Detected 2 ports
Jan 1 01:00:05 kernel: usb.c: new USB bus registered, assigned bus number 1
Jan 1 01:00:05 kernel: hub.c: USB hub found
Jan 1 01:00:05 kernel: hub.c: 2 ports detected
Jan 1 01:00:06 kernel: PCI: Enabling device 01:02.1 (0000 -> 0001)
Jan 1 01:00:06 kernel: usb-uhci.c: USB UHCI at I/O 0x120, IRQ 2
Jan 1 01:00:06 kernel: usb-uhci.c: Detected 2 ports
Jan 1 01:00:06 kernel: usb.c: new USB bus registered, assigned bus number 2
Jan 1 01:00:06 kernel: hub.c: USB hub found
Jan 1 01:00:06 kernel: hub.c: 2 ports detected
Jan 1 01:00:06 kernel: usb-uhci.c: v1.275:USB Universal Host Controller Interface driver
Jan 1 01:00:06 kernel: PCI: Enabling device 01:02.2 (0000 -> 0002)
Jan 1 01:00:06 kernel: ehci_hcd 01:02.2: PCI device 1106:3104
Jan 1 01:00:06 kernel: ehci_hcd 01:02.2: irq 2, pci mem c00a4000
Jan 1 01:00:06 kernel: usb.c: new USB bus registered, assigned bus number 3
Jan 1 01:00:06 kernel: PCI: 01:02.2 PCI cache line size set incorrectly (0 bytes) by BIOS/FW, correcting to 32
Jan 1 01:00:06 kernel: ehci_hcd 01:02.2: USB 2.0 enabled, EHCI 1.00, driver 2003-Dec-29/2.4
Jan 1 01:00:06 kernel: hub.c: 4 ports detected
Jan 1 01:00:06 kernel: usb.c: registered new driver usblp
Jan 1 01:00:06 kernel: printer.c: v0.13: USB Printer Device Class driver
Jan 1 01:00:08 kernel: usb.c: registered new driver audio
Jan 1 01:00:08 kernel: audio.c: v1.0.0:USB Audio Class driver
Jan 1 01:00:08 kernel: Linux video capture interface: v1.00
Jan 1 01:00:08 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 01:00:09 kernel: Initializing USB Mass Storage driver...
Jan 1 01:00:09 kernel: usb.c: registered new driver usb-storage
Jan 1 01:00:09 kernel: USB Mass Storage support registered.
Jan 1 01:00:09 kernel: eth0.1: del 33:33:ff:9f:97:48 mcast address from master interface
Jan 1 01:00:09 kernel: eth0.1: del 33:33:ff:9f:97:48 mcast address from vlan interface
Jan 1 01:00:09 kernel: eth0.1: del 33:33:00:00:00:01 mcast address from master interface
Jan 1 01:00:09 kernel: eth0.1: del 33:33:00:00:00:01 mcast address from vlan interface
Jan 1 01:00:09 kernel: br0: port 2(eth0.1) entering disabled state
Jan 1 01:00:09 kernel: eth0.1: dev_set_promiscuity(master, 1)
Jan 1 01:00:09 kernel: eth0.1: add 33:33:00:00:00:01 mcast address to master interface
Jan 1 01:00:09 kernel: eth0.1: add 33:33:ff:9f:97:48 mcast address to master interface
Jan 1 01:00:09 kernel: br0: port 2(eth0.1) entering listening state
Jan 1 01:00:09 kernel: br0: port 2(eth0.1) entering learning state
Jan 1 01:00:09 kernel: br0: port 2(eth0.1) entering forwarding state
Jan 1 01:00:09 kernel: br0: topology change detected, propagating
Jan 1 01:00:09 udhcpc[80]: udhcpc (v0.9.9-pre) started
Jan 1 01:00:09 dnsmasq[58]: read /etc/hosts - 5 addresses
Jan 1 01:00:09 dnsmasq[58]: read /etc/ethers - 2 addresses
Jan 1 01:00:09 dnsmasq[58]: reading /tmp/resolv.conf
Jan 1 01:00:09 dhcp client: deconfig: lease is lost
Jan 1 01:00:10 udhcpc[80]: Lease of 82.238.39.116 obtained, lease time 604800
Jan 1 01:00:10 dnsmasq[58]: read /etc/hosts - 5 addresses
Jan 1 01:00:10 dnsmasq[58]: read /etc/ethers - 2 addresses
Jan 1 01:00:10 dnsmasq[58]: reading /tmp/resolv.conf
Jan 1 01:00:10 dnsmasq[58]: using nameserver 213.228.0.95#53
Jan 1 01:00:10 dnsmasq[58]: using nameserver 212.27.54.252#53
Jan 1 01:00:10 dhcp client: bound IP : 82.238.39.116 from 82.238.39.254
Jan 1 00:00:13 dnsmasq[58]: DHCPREQUEST(br0) 192.168.1.2 00:02:2d:40:87:4f
Jan 1 00:00:13 dnsmasq[58]: DHCPACK(br0) 192.168.1.2 00:02:2d:40:87:4f e500
Jan 1 00:00:16 dnsmasq[58]: DHCPREQUEST(br0) 192.168.1.2 00:02:2d:40:87:4f
Jan 1 00:00:16 dnsmasq[58]: DHCPACK(br0) 192.168.1.2 00:02:2d:40:87:4f e500
Jun 16 21:03:28 dnsmasq[58]: DHCPREQUEST(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:03:28 dnsmasq[58]: DHCPACK(br0) 192.168.1.2 00:02:2d:40:87:4f e500
Jun 16 21:03:32 ntp client: Synchronizing time with time.nist.gov ...
Jun 16 21:03:54 dnsmasq[58]: DHCPDISCOVER(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:03:54 dnsmasq[58]: DHCPOFFER(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:03:54 dnsmasq[58]: DHCPREQUEST(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:03:54 dnsmasq[58]: DHCPACK(br0) 192.168.1.2 00:02:2d:40:87:4f e500
Jun 16 21:05:30 dnsmasq[58]: DHCPRELEASE(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:05:30 dnsmasq[58]: DHCPDISCOVER(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:05:30 dnsmasq[58]: DHCPOFFER(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:05:30 dnsmasq[58]: DHCPREQUEST(br0) 192.168.1.2 00:02:2d:40:87:4f
Jun 16 21:05:30 dnsmasq[58]: DHCPACK(br0) 192.168.1.2 00:02:2d:40:87:4f e500
Jun 16 21:06:18 login[104]: root login on `pts/0'
Jun 16 21:06:46 kernel: hub.c: new USB device 01:02.0-2, assigned address 2
Jun 16 21:06:46 kernel: printer.c: usblp0: USB Bidirectional printer dev 2 if 0 alt 0 proto 2 vid 0x04A9 pid 0x262B
Jun 16 21:06:46 kernel: printer.c: usblp0 Device ID string [94]='MFG:Canon;MDL:LASER SHOT LBP-1120;CMD:CAPT;VER:1.0;CLS:PRINTER;DES:Canon LASER SHOT LBP-1120'
And when I print I have:
Jun 16 22:06:10 p9100d[69]: Connection from 192.168.1.2 port 3278 accepted
Jun 16 22:06:10 p9100d[69]: /dev/usb/lp0: No such device
Jun 16 22:06:11 p9100d[69]: Finished job: 185260 bytes received
Actually I still have this message in the system tray:
