I use the firmware crond and crontab. In de post-mount/post-boot script I enter mkdir -f /var/spool/cron/crontabs. Copy the cron file (e.g. admin) to the /var/spool/cron/crontabs directory and start crond. Works like a charm!You could use the flashfs tool to store the cron tab (the file admin), so no external USB storage needed. .Code:#!/bin/sh mkdir -p /var/spool/cron/crontabs cp /tmp/harddisk/own/admin /var/spool/cron/crontabs/. crond
Good luck!
