http://wl500g.info/search.php?searchid=185479
the answer is here..
just remove the line
I'm trying for a few hours to Compile the new Hardware for my WL-HDD.
As I started to read the Forum, I thought I need the Sources from th WRT54G, downloaded it put the wl500g-1.9.2.7-5a.tar.bz2 in the right DIR didn't work I ended up with downloading GPL_1927.zip aka GPL_1927.tar.gz extracted wl500g-1.9.2.7-5a.tar.bz2 in broadcm/src
did a
make uClibc
make kernel
make
and it jumed out with:
patching file www/asus/mkweb
[ ! -d /usr/src/ASUS-WL-HDD/broadcom/src/router/rt2460 ] || [ -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway/rt2460 ] || \
tar -C /usr/src/ASUS-WL-HDD/broadcom/src/router -cf - rt2460 | tar -C /usr/src/ASUS-WL-HDD/broadcom/src/gateway -xf-
[ ! -f rt2460.diff ] || patch -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway -p1 --no-backup-if-mismatch < rt2460.diff
[ ! -d /usr/src/ASUS-WL-HDD/broadcom/src/router/et.SENTRY5 ] || [ -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway/et.SENTRY5 ]|| \
tar -C /usr/src/ASUS-WL-HDD/broadcom/src/router -cf - et.SENTRY5 | tar -C /usr/src/ASUS-WL-HDD/broadcom/src/gateway-xf -
[ ! -f et.SENTRY5.diff ] || patch -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway -p1 --no-backup-if-mismatch < et.SENTRY5.diff
[ ! -d /usr/src/ASUS-WL-HDD/broadcom/src/router/libcrypto ] || [ -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway/libcrypto ] || \
tar -C /usr/src/ASUS-WL-HDD/broadcom/src/router -cf - libcrypto | tar -C /usr/src/ASUS-WL-HDD/broadcom/src/gateway -xf -
[ ! -f libcrypto.diff ] || patch -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway -p1 --no-backup-if-mismatch < libcrypto.diff
patching file libcrypto/Makefile
[ -f /usr/src/ASUS-WL-HDD/broadcom/src/gateway/Makefile ] || cp /usr/src/ASUS-WL-HDD/broadcom/src/router/Makefile /usr/src/ASUS-WL-HDD/broadcom/src/gateway && patch -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway -p1 < Makefile.diff
patching file Makefile
[ -f /usr/src/ASUS-WL-HDD/broadcom/src/gateway/Makefiles5.mk ] || cp /usr/src/ASUS-WL-HDD/broadcom/src/router/Makefiles5.* /usr/src/ASUS-WL-HDD/broadcom/src/gateway && patch -d /usr/src/ASUS-WL-HDD/broadcom/src/gateway -p1 < Makefiles5.diff
/bin/sh: Makefiles5.diff: No such file or directory
make: *** [custom] Error 1
Does any body know what I'm doing wrong here ?
By the way I did the uClibC stuff and enhanced the PATH-Variable also.
The reason for this recompiling stuff is, I would like to add otherstuff to it and do some changes on the WEBCAM-Kernel-Modules, because the drive is thinking I've got another CAM and the maintainer of the CAM-Modules told me to do some changes in the Source and recompile it !!!
Thanks in advanced
sincerly
A.Kneiseler
Greetings from 1XXXX (Berlin/Germany)
Well it's kind of a big, annoying issue actually, because then it has to bother you with "are you sure you want to apply the patch" and everything when you try again, so basically to avoid hassle you have to start over. It would be quite nice if the patches could be reuploaded with this fixed along with the default model changed to WL500g, but that's just my humble opinion.Originally Posted by Antiloop
Opps I hit the link and it shows me
Anyway, I'll doit!Originally Posted by vBulletin Message
Thanks again
Andy
search for: Makefiles5.diff
anyway just remove the line that needs it
OK it's done.
I did updated the pwc Modules from 8.8 to 9.02 that's the last one I could easy integrate in to this kernel (Only copying the files to linux/linux/usb. The other updates were to dificult to do a quick hack, because they need some header-files from 2.6.xx. Did the patch sugested at the MList from http://www.saillard.org/linux/pwc/ still doesn't work, it now knows my Philips ToUCam 740K but no pictures.
Bad thing, when I've got Time I'll try the newer ones. Thanks again for your help !!
Does anybody has his Philips ToUCam 740K working with this thing, it always tells me I got a Sotec Alfina but i know for sure I've got a Philips (my moneybag too)
Andy
since I played a lot with the Development tree, I wrote myself a script, thats removing the old stuff and rebuilding the tree from the tarballs.
On a P42.4 it goes quick for this amount of data until everything is finished !!
perhaps the chipset is from 'Sotec' or something, is the 740K a Pro series ? if not then you can be almost sure it is not a philips chipset insideOriginally Posted by ankn99
It's a PCVC740K
Pictures and Info is here:
http://www.pc-cameras.philips.com/ma...40k/index.html
I opened the cam there sits a Philips SAA9999999 somthing inside of it.
XP SP1 used to work with it without any Probl. but since SP2 it doesn't deetect it automagicly !!!
I', not sure but I think I remember, that there is a Chip that may be reprogrammed by any application ??
Andy
