Results 1 to 8 of 8
Thread: Problem to mount my hd to have twonky working
    Hello, I'm still getting problem having my twonky working properly
    I am unable to mount my harddrive under /tmp/harddisk
    My router Asus WL500W auto mount it to /tmp/mnt/disc0_1
    I have been able to force the umoun then tried to mount it using
    mount /dev/discs/disc0/part1 /tmp/harddisk
    but when a do a df i'm still having it mounted to /tmp/mnt/disc0_1 instead of /tmp/harddisk
    See under
    Filesystem 1K-blocks Used Available Use% Mounted on
    /dev/root 3072 3072 0 100% /
    tmpfs 15028 212 14816 1% /tmp
    244992064 34624 244957440 0% /tmp/mnt/disc0_1
    [admin@WL-0023545F7BF1 root]$ umount -l /tmp/mnt/disc0_1
    [admin@WL-0023545F7BF1 root]$ df
    [admin@WL-0023545F7BF1 root]$ mount /dev/discs/disc0/part1 /tmp/harddisk
    Would someone have an idea why ?
    Thanks
    Cyberic
    Feb 2005
    Germany - Frankfurt
    edit your /etc/fstab:
    /dev/discs/disc0/part1  /tmp/harddisk   ext3    rw,noatime      1       1
    OR
    use "ln -s /tmp/mnt/disc0_1 /tmp/harddisk"
    wengi
    Hi Wengi
    I first tried
    tmpfs 15028 260 14768 2% /tmp
    [admin@WL-0023545F7BF1 root]$ ln -s /tmp/mnt/disc0_1 /tmp/harddisk
    ln: /tmp/harddisk/disc0_1: Operation not permitted
    Then a create a file fstab under etc/
    adding the code
    and saved it as etc/fstab then reboot my rooter
    didn't work either
    Was I ok when a create the fstab file under etc/
    I was not sure about that ?
    Thansk
    The Netherlands - Eindhoven
    Do you want to install the new 6.0.1 version?
    mounting things like that doesn't always work out, so for the new version I decided to do everything via the console, which is easier
    I made a little "beta" howto on my backup forum: http://wpte.kicks-ass.net/forum/showthread.php?tid=3
    I'm still testing it, but it should work quite allright
    Feb 2005
    Germany - Frankfurt
    to get this right:
    You have which hardware, firmware, setup?
    wengi
    Quote Originally Posted by wengi View Post
    to get this right:
    wengi
    a version from googlecode it seems: http://wl500g.info/showpost.php?p=208163&postcount=11
    Isn't a flash save required to permanently change fstab?
    I have Twonky and my media files on self chosen places in my system. As long as you call twonky right during booting.
    Jul 2007
    Germany, Bonn
    Hey,
    why posting in the Tutorials-Section??
    You're not sharing a Tutorial, or?
    Moved to Q&A!
    Regards / Grüße,
    Oliver
    Clients: Kathrein UFS910 FullHD Sat Receiver, PS3, PCs, Canon MP830 an Sane Scanner-Server, Kyocera-Mita FS1020D über Printserver
  1. Problem: WL500gpV2, twonky, xbox360 and oleg.
    By chervee in forum WL-500gP Q&A
    Last Post: 29-08-2009, 16:53
  2. Replies: 7
    Last Post: 20-04-2009, 17:55
  3. Mount problem (strenge)
    By qczek in forum WL-500g Custom Development
    Last Post: 01-02-2006, 13:05
