Jan 1 00:00:05 syslogd started: BusyBox v1.19.3
Jan 1 00:00:05 kernel: klogd started: BusyBox v1.19.3 (2011-12-25 19:08:59 MSK)
Jan 1 00:00:05 kernel: Linux version 2.6.22.19 (root@localhost) (gcc version 4.4.6 (GCC) ) #1 Sun Dec 25 19:08:36 MSK 2011
Jan 1 00:00:05 kernel: CPU revision is: 00019749
Jan 1 00:00:05 kernel: Found a 4MB ST compatible serial flash
Jan 1 00:00:05 kernel: Determined physical RAM map:
Jan 1 00:00:05 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 00:00:06 dnsmasq[208]: started, version 2.59 cachesize 512
Jan 1 00:00:06 dnsmasq[208]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n DHCP no-scripts no-TFTP no-conntrack no-IDN
Jan 1 00:00:06 dnsmasq-dhcp[208]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jan 1 00:00:06 dnsmasq[208]: read /etc/hosts - 2 addresses
Jan 1 00:00:06 miniupnpd[210]: version 1.6 started
Jan 1 00:00:06 miniupnpd[210]: HTTP listening on port 41582
Jan 1 00:00:06 miniupnpd[210]: Listening for NAT-PMP traffic on port 5351
Jan 1 00:00:06 kernel: br0: port 1(vlan0) entering disabled state
Jan 1 00:00:06 kernel: vlan0: dev_set_promiscuity(master, 1)
Jan 1 00:00:06 kernel: br0: port 1(vlan0) entering forwarding state
Jan 1 00:00:07 dhcp client: skipping resetting IP address to 0.0.0.0
Jan 1 00:00:07 dhcp client: deconfig: lease is lost
Jan 1 00:00:10 dnsmasq-dhcp[208]: DHCPREQUEST(br0) 192.168.1.19 90:a4:de:8b:7e:92
Jan 1 00:00:10 dnsmasq-dhcp[208]: DHCPACK(br0) 192.168.1.19 90:a4:de:8b:7e:92 Harsh
Jan 1 00:00:16 pptp[240]: Plugin pptp.so loaded.
Jan 1 00:00:16 pptp[240]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Jan 1 00:00:17 pptp[241]: pppd 2.4.5 started by admin, uid 0
Jan 1 00:00:17 pptp[241]: PPTP: Unknown host vpn.internet.beeline.ru
Jan 1 00:00:28 wan: connected manually
Jan 1 00:00:28 dnsmasq[208]: read /etc/hosts - 2 addresses
Jan 1 00:00:28 zcip client: config IP : 169.254.220.47
Jan 1 00:00:47 pptp[241]: PPTP: Unknown host vpn.internet.beeline.ru
Jan 1 00:00:06 miniupnpd[210]: HTTP listening on port 33333
Jan 1 00:00:13 dnsmasq-dhcp[208]: DHCPREQUEST(br0) 192.168.1.19 90:a4:de:8b:7e:92
Jan 1 00:00:13 dnsmasq-dhcp[208]: DHCPACK(br0) 192.168.1.19 90:a4:de:8b:7e:92 Harsh
Jan 1 00:00:16 l2tpd[241]: tunnel_establish: gethostbyname failed for 'tp.corbina.ru'
Jan 1 00:00:46 l2tpd[241]: tunnel_establish: gethostbyname failed for 'tp.corbina.ru'
Jan 1 00:01:03 wan: connected manually
Вот логи. Район Нагатино-Садовники. В последнем логе не хватает двух строк о не удачной попытке соединения.
