Trust soundforce works perfectly, the plugin is kinda buggy, causes WMP to crash at exit..
Hello,
Can someone confirm that the 500gd version of the router has the capibility to use the usb speaker plug-in?
I'm kinda confused: The download section of the 500gd does not mention the usb speaker plug-in for WMP, as the 500G explicitly does.
I'm planning on buying the Trust SoundForce 2012 speaker set, can someone also confirm the compatibility of the speakers with the 500gd?
I'm a proud owner of a WL500gx-01-03-01-33
TIA,
Agent_Sandoval
