Все поля действительно не заполнены, скриншот я никак не редактировал.
Вот ещё полный лог с момента запуска:
Jan 1 03:00:03 syslogd started: BusyBox v1.18.3
Jan 1 03:00:03 kernel: klogd started: BusyBox v1.18.3 (2011-03-12 14:10:16 MSK)
Jan 1 03:00:03 kernel: Linux version 2.6.22.19 (root@localhost) (gcc version 4.3.5 (GCC) ) #6 Sat Mar 12 14:58:22 MSK 2011
Jan 1 03:00:03 kernel: CPU revision is: 00029006
Jan 1 03:00:03 kernel: Setting the PFC to its default value
Jan 1 03:00:03 kernel: Determined physical RAM map:
Jan 1 03:00:03 kernel: memory: 02000000 @ 00000000 (usable)
Jan 1 03:00:03 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 1 03:00:03 kernel: Physically mapped flash: CFI does not contain boot bank location. Assuming top.
Jan 1 03:00:03 kernel: number of CFI chips: 1
Jan 1 03:00:03 kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Jan 1 03:00:03 kernel: Flash device: 0x800000 at 0x1c000000
Jan 1 03:00:03 kernel: Physically mapped flash: squashfs filesystem found at block 1303
Jan 1 03:00:03 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Jan 1 03:00:03 kernel: 0x00000000-0x00040000 : "boot"
Jan 1 03:00:03 kernel: 0x00040000-0x007f0000 : "linux"
Jan 1 03:00:03 kernel: 0x00145f6c-0x007f0000 : "rootfs"
Jan 1 03:00:03 radvd[214]: version 1.7 started
Jan 1 03:00:03 dnsmasq[219]: started, version 2.57 cachesize 512
Jan 1 03:00:03 dnsmasq[219]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N DHCP no-scripts no-TFTP no-IDN
Jan 1 03:00:03 dnsmasq-dhcp[219]: DHCP, IP range 10.13.0.128 -- 10.13.0.253, lease time 1d
Jan 1 03:00:03 dnsmasq[219]: read /etc/hosts - 10 addresses
Jan 1 03:00:03 dnsmasq-dhcp[219]: read /etc/ethers - 7 addresses
Jan 1 03:00:04 kernel: usbcore: registered new interface driver usbfs
Jan 1 03:00:04 kernel: usbcore: registered new interface driver hub
Jan 1 03:00:04 kernel: usbcore: registered new device driver usb
Jan 1 03:00:04 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan 1 03:00:04 kernel: PCI: Enabling device 0000:01:03.2 (0000 -> 0002)
Jan 1 03:00:04 kernel: ehci_hcd 0000:01:03.2: EHCI Host Controller
Jan 1 03:00:04 kernel: ehci_hcd 0000:01:03.2: new USB bus registered, assigned bus number 1
Jan 1 03:00:04 kernel: ehci_hcd 0000:01:03.2: irq 12, io mem 0x40004000
Jan 1 03:00:04 kernel: ehci_hcd 0000:01:03.2: USB 2.0 started, EHCI 1.00
Jan 1 03:00:04 kernel: usb usb1: configuration #1 chosen from 1 choice
Jan 1 03:00:04 kernel: hub 1-0:1.0: USB hub found
Jan 1 03:00:04 kernel: hub 1-0:1.0: 4 ports detected
Jan 1 03:00:04 kernel: uhci_hcd: USB Universal Host Controller Interface driver
Jan 1 03:00:04 kernel: PCI: Enabling device 0000:01:03.0 (0000 -> 0001)
Jan 1 03:00:04 kernel: uhci_hcd 0000:01:03.0: UHCI Host Controller
Jan 1 03:00:05 kernel: uhci_hcd 0000:01:03.0: new USB bus registered, assigned bus number 2
Jan 1 03:00:05 kernel: uhci_hcd 0000:01:03.0: irq 12, io base 0x00000100
Jan 1 03:00:05 kernel: usb 1-2: new high speed USB device using ehci_hcd and address 2
Jan 1 03:00:05 kernel: usb usb2: configuration #1 chosen from 1 choice
Jan 1 03:00:05 kernel: hub 2-0:1.0: USB hub found
Jan 1 03:00:05 kernel: hub 2-0:1.0: 2 ports detected
Jan 1 03:00:05 kernel: PCI: Enabling device 0000:01:03.1 (0000 -> 0001)
Jan 1 03:00:05 kernel: uhci_hcd 0000:01:03.1: UHCI Host Controller
Jan 1 03:00:05 kernel: uhci_hcd 0000:01:03.1: new USB bus registered, assigned bus number 3
Jan 1 03:00:05 kernel: uhci_hcd 0000:01:03.1: irq 12, io base 0x00000120
Jan 1 03:00:05 kernel: usb usb3: configuration #1 chosen from 1 choice
Jan 1 03:00:05 kernel: hub 3-0:1.0: USB hub found
Jan 1 03:00:05 kernel: hub 3-0:1.0: 2 ports detected
Jan 1 03:00:05 kernel: usb 1-2: configuration #1 chosen from 1 choice
Jan 1 03:00:05 kernel: usbcore: registered new interface driver usblp
Jan 1 03:00:06 kernel: Linux video capture interface: v2.00
Jan 1 03:00:07 kernel: usbcore: registered new interface driver uvcvideo
Jan 1 03:00:07 kernel: USB Video Class driver (v0.1.0)
Jan 1 03:00:07 kernel: SCSI subsystem initialized
Jan 1 03:00:07 kernel: Initializing USB Mass Storage driver...
Jan 1 03:00:07 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan 1 03:00:07 kernel: usbcore: registered new interface driver usb-storage
Jan 1 03:00:07 kernel: USB Mass Storage support registered.
Jan 1 03:00:08 kernel: NTFS driver 2.1.28 [Flags: R/O MODULE].
Jan 1 03:00:09 kernel: scsi 0:0:0:0: Direct-Access Kingston DT 101 G2 1.00 PQ: 0 ANSI: 2
Jan 1 03:00:09 kernel: sd 0:0:0:0: [sda] 7818184 512-byte hardware sectors (4003 MB)
Jan 1 03:00:09 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan 1 03:00:09 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan 1 03:00:09 kernel: sda: sda1
Jan 1 03:00:10 kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Jan 1 03:00:15 login[667]: root login on 'pts/0'
Jan 1 03:00:17 dhcp client: skipping resetting IP address to 0.0.0.0
Jan 1 03:00:17 dhcp client: deconfig: lease is lost
Jan 1 03:00:25 udpxy[1640]: udpxy 1.0-Chipmunk (build 19) standard is starting
Jan 1 03:00:25 kernel: vlan1: dev_set_allmulti(master, 1)
Jan 1 03:00:25 dnsmasq[219]: read /etc/hosts - 10 addresses
Jan 1 03:00:25 dnsmasq-dhcp[219]: read /etc/ethers - 7 addresses
Jan 1 03:00:25 dnsmasq[219]: using nameserver 80.252.130.254#53
Jan 1 03:00:25 dnsmasq[219]: using nameserver 80.252.130.253#53
Jan 1 03:00:25 dhcp client: bound IP : 10.205.50.123 from 10.205.50.254
Jan 1 03:00:26 pppd[1655]: Plugin pppol2tp.so loaded.
Jan 1 03:00:26 pppd[1655]: pppd 2.4.5 started by Cluster, uid 0
Jan 1 03:00:26 pppd[1655]: Using interface ppp0
Jan 1 03:00:26 pppd[1655]: Connect: ppp0 <--> l2tp (10.255.255.254)
Jan 1 03:00:26 kernel: EXT3-fs: starting recovery.
Jan 1 03:00:26 kernel: kjournald starting. Commit interval 5 seconds
Jan 1 03:00:26 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Jan 1 03:00:26 kernel: EXT3 FS on sda1, internal journal
Jan 1 03:00:26 kernel: EXT3-fs: recovery complete.
Jan 1 03:00:26 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 1 03:00:27 pppd[1655]: CHAP authentication succeeded
Jan 1 03:00:27 pppd[1655]: local LL address fe80::f5c0:eee9:83d7:fd6d
Jan 1 03:00:27 pppd[1655]: remote LL address fe80::0224:14ff:fe28:b700
Jan 1 03:00:27 pppd[1655]: local IP address 178.167.105.239
Jan 1 03:00:27 pppd[1655]: remote IP address 10.255.255.254
Jan 1 03:00:27 pppd[1655]: primary DNS address 80.252.130.254
Jan 1 03:00:27 pppd[1655]: secondary DNS address 80.252.130.253
Jan 1 03:00:27 dropbear[1679]: Running in background
Jan 1 03:00:27 dnsmasq[219]: read /etc/hosts - 10 addresses
Jan 1 03:00:27 dnsmasq-dhcp[219]: read /etc/ethers - 7 addresses
Jan 1 03:00:27 dnsmasq[219]: using nameserver 80.252.130.253#53
Jan 1 03:00:27 dnsmasq[219]: using nameserver 80.252.130.254#53
Jan 1 03:00:35 INADYN[2302]: Started 'INADYN version 1.96.3' - dynamic DNS updater.
Jan 1 03:00:35 INADYN[2302]: IP read from cache file is '178.167.28.36'. No update required.
Jan 1 03:00:35 L2TP: connected to ISP
Jan 1 03:00:36 INADYN[2302]: I:IP address for alias 'clusterrr.homeip.net' needs update to '178.167.105.239'
Jan 1 03:00:36 INADYN[2302]: I:Alias 'clusterrr.homeip.net' to IP '178.167.105.239' updated successful.
Jan 1 03:00:37 ddns: ddns update ok
Mar 14 23:28:30 pppd[1655]: System time change detected.
OpenVPN на всякий случай отключил.
Только что пришлось два раза перезагрузить роутер, чтобы эти IPv6 адреса опять появились.
