Results 1 to 2 of 2
Thread: USB flash drives works, not HDDs on WL500g
    Hi
    Thanks to this forum and firmware I bought my first WL500g ~2004 and it's still working perfectly (also a WL550gE present on the LAN).
    Lately I have had the need for an inexpensive NAS-solution and Samba, so I tried to mount USB flash drives and HDDs.
    USB flash drive (FAT formated) works perfectly and works with samba:
    Jun 21 13:34:56 kernel: hub.c: new USB device 00:04.0-1, assigned address 4
    Jun 21 13:34:56 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
    Jun 21 13:34:56 kernel:   Vendor: 128MB     Model: HardDrive         Rev: 1.88
    Jun 21 13:34:56 kernel:   Type:   Direct-Access                      ANSI SCSI revision: 02
    Jun 21 13:34:56 kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
    Jun 21 13:34:56 kernel: SCSI device sda: 256000 512-byte hdwr sectors (131 MB)
    Jun 21 13:34:56 kernel: sda: Write Protect is off
    Jun 21 13:34:56 kernel: Partition check:
    Jun 21 13:34:56 kernel:  p1
    Jun 21 13:35:01 USB storage: vfat fs at /dev/discs/disc0/part1 mounted to /tmp/mnt/disc0_1
    However, when mounting a WD My passport or WD Elements 2TB (formated in EXT3) it does not work:
    Jun 21 13:43:53 kernel: hub.c: new USB device 00:04.0-1, assigned address 7
    Jun 21 13:44:03 kernel: Device not ready.  Make sure there is a disc in the drive.
    Jun 21 13:44:03 kernel: sda : READ CAPACITY failed.
    Jun 21 13:44:03 kernel: sda : status = 1, message = 00, host = 0, driver = 08
    Jun 21 13:44:03 kernel: Info fld=0xa00 (nonstd), Current sd00:00: sns = 70  2
    Jun 21 13:44:03 kernel: Raw sense data:0x70 0x00 0x02 0x00 0x00 0x0a 0x00 0x00
    Jun 21 13:44:03 kernel: sda : block size assumed to be 512 bytes, disk size 1GB.
    Jun 21 13:44:03 kernel:  /dev/scsi/host0/bus0/target0/lun0: I/O error: dev 08:00, sector 0
    Jun 21 13:44:03 kernel:  I/O error: dev 08:00, sector 0
    Jun 21 13:44:03 kernel:  unable to read partition table
    I can locate a 20MB NTFS partition there via samba which I can't write to.
    Why doesn't it work?
    Does it not support EXT3?
    Is there any chance that another firmware (like dd-wrt) will accept this HDD?
    Firmware= 1.9.2.7-9 (=latest)
    The ext3-partition is probably not a primary partition. I guess you have to repartition / reformat the drive directly on your router.
    http://wl500g.info/showpost.php?p=60931&postcount=2
  1. Загрузка с USB flash на устройствах с 2Mb flash (Asus WL-520gC)
    By lightix in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 15-04-2011, 12:26
  2. Usb Hdd nicht mehr erkannt in olegs FW
    By Alex09 in forum German Discussion - Deutsch (DE)
    Last Post: 30-06-2010, 14:02
  3. cannot detect USB HDD
    By ferdz_33 in forum WL-500gP Q&A
    Last Post: 13-01-2010, 08:53
  4. 7.09 + USB + hotplug
    Last Post: 18-11-2007, 13:51
