Originally Posted by
Petule
Hello Guys,
Some weeks ago my NB suddenly stopped to detect the wifi from my asus. I checked the router and WAN + LANs worked. All the LEDs (WAN, LANs, POWER) were on except of AIR. Also power off / on again did not help.
I went through some forums to find out that the power supply could be damaged (capacitors issue). So I changed the power supply to the stronger one (5V/3A). After this, the problem was gone, LED AIR normally lit and my wifi worked. Yesterday, the same issue appeared (no wireless) so I found another power supply but no positive effect this time.
My last working firmware was 1.9.2.7-10, but currently I set everything to default. Unfortunately guarantee period finished 2months ago.
Can anyone help, pleeeeeeeeeeeease????
Thank you all so much
Regards
Petule
