Results 1 to 6 of 6
Thread: Mass Storage replacement
    Dear WL-500gP users,
    I would like to replace my USB HDD (320Gb) with 2Gb flash drive. My router has Oleg's FW ver. 1.9.2.7-10 and it is installed according to tutorial in showthread.php?t=10307.
    Is there a simple way to copy the /opt partition to the flash drive, or I have to reinstall the packages and create the scripts from scratch?
    I'm also planning to upgrade to the new version from Google code. Will it effect my old installation?
    Thanx and regards,
    T.
    Sep 2007
    czech republic
    Quote Originally Posted by trymyluck View Post
    Thanx and regards,
    T.
    1) http://wl500g.info/showpost.php?p=110136&postcount=7 / use some win app like Acronis.
    2) do not know, startup scripts in flashfs is same, config files not. Backup both first.
    RT-N13u dd-wrt | Toshiba 2.5" 160GB | pxe boot server
    Dear gouryella,
    thank you for your fast reply.
    The method described in the posted link is for target > source. But I have the opposite case.
    I'm not sure about Acronis, because I'm afraid that it will change my rights
    Any other ideas?
    T.
    After you have manually partitioned the new HDD a simple "cp -ax" from the old to the new partitions should do the trick.
    No messing around with Acronis and stuff.
    Are you aware that USB-Sticks have wearout? After ∼ 100.000 to 1.000.000 write cycles, memory is broken.
    I would do a complete new installation. Maybe with this script:
    http://wl500g.info/showthread.php?t=21774
    If you dont Swap on the Stick wearout should not be a problem.
    An 1,8" HDD would be an alternative, i use an old iPod drive.
    Modern drives are available for approx 50€ / 120Gig.
    Complete new install is not necessary, i have done the same (from the last Oleg to enthusiast) without any big problems.
    If the web UI dosnt come up again, wait 10 or 15 min and then unplug the Router from his power Cord to restard. One thing that could accour is that you dont have SSH directly after upgrade.
  1. Use USB as storage
    By zerg in forum WL-500gP Q&A
    Last Post: 16-02-2010, 20:05
  2. Second storage device added to WL-500gp
    By citro in forum WL-500gP Q&A
    Last Post: 02-02-2009, 22:09
  3. V2 usb storage files missing
    By kemy in forum WL-500gP Q&A
    Last Post: 30-04-2008, 22:12
  4. automount USB mass storage device
    By starbright in forum WL-HDD Custom Development
    Last Post: 16-01-2007, 19:24
