Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: nvram, nvram_x
    Nvram.
    I have a lama question to ask. I got a Asus 500g and I would like to do following changes 16_x_FIsFtpServer=0, wan_ifname=ppp0. I have used nvram set wan_ifname=ppp0; nvram commit. However, I still get old values after reboot. Can anyone tell me where I make a mistake? Is it hard coded somewhere without a change to change it?
    Best regards
    Jamie Poz.
    Saving nvram value
    I would like to know if every setting I can set up on Oleg's firmware is set in nvram value, and if so, is it possible to do a manual backup and restore.
    I would like to go back from a mixed state configuration set and also to do a kind of configuration switch?
    Everything accessible via web interface is stored in the nvram.
    but how can you make a backup restore in one operation? Do I have to script the nvram command, or can I use a /dev/mtd in some way?
    after searching, there is some info about nvram_x, but this utility looked buggy and does'nt exist anymore. Do I have to script all value to save and restore nvram, or is there a new command to do so?
    Just use built-in save/restore configuration function. I think this should be enough for you.
    yes, but it doesn't work on Wl-Hdd. I get a WLHDD.cfg file with 0k size.
    On wl500 version (when I was testing it before your actual version for wl hdd), it was working.
    Also, this method ask for a browser. I would need a telnet way, as I will be using non standard browsers.
    Well, you can play dangerous game with nvram then:
    cat /dev/mtd/3 > /tmp/nvram.bin
    should backup whole nvram
    flash /tmp/nvram.bin /dev/mtd/3
    reboot
    should bring it back.
    Remove from nvram
    Is there a command I can use to remove entries from nvram?
    I have UPnP entries that have been storded to nvram that I would like to remove. I find them with this command:
    nvram show | grep forward_port
    I could of course reset to factory default, but I'd rather not...
    S.
    May 2004
    Quote Originally Posted by barsju
    S.
    nvram unset var_name
    or smthg similar should work, I believe.
    HTH
    Roofcat
    Nov 2003
    Eindhoven
    Quote Originally Posted by RoofCat
    HTH
    Roofcat
    indeed that will work
    also
    nvram set var_name
    should work to erase the entry
    after doing this do a commit
    nvram commit
    Thx! That works, and now I'm working on a script like this:
    i=$1
    while [ $i -le $2 ]
    do
            nvram unset  port_forward$i
            i=$i + 1
    done
    but I keep getting
    ./clearUPnP: 8: +: not found
    What gives??
    S.
