Is there any possibility to ad IPTV settings in Oleg's Firmware for Asus RT-N16. Because original Asus FW already has that support, but original Asus FW sucks.
The legacy firmware code sets tx power in mw units, but asus doesn't set tx power at all.
moreower, radio power in ranged in 1 - 1496 mw, not in 1 - 84.
so, check tx power on asus firmware with
and set the value on 1.9.2.7-rtn withCode:wl txpwr1
keep in mind, qdbm_value is ranged from 1 to 127.Code:wl txpwr1 -q qdbm_value -o
my current values:
[admin@rt-n16 root]$ wl txpwr1
TxPower is 127 qdbm, 31.75 dbm, 1496 mW Override is Off
ASUS WL5xx: FW 1.9.2.7-d-rXXXX / îáñóæäåíèå ïðîøèâêè [RU] / firmware discussion [EN] | bip irc proxy
ASUS RT-N1x: FW 1.9.2.7-rtn-rXXXX / îáñóæäåíèå ïðîøèâêè [RU] / firmware discussion [EN] | fake ident daemon
Ok - made some tests...
Asus 1.0.1.2:
Oleg:
TxPower is 51 qdbm, 12.75 dbm, 19 mW Override is Off
The GUI setting of Radio Power only allows a value of 1-84. 84 entered in GUI gives:
TxPower is 77 qdbm, 19.25 dbm, 84 mW Override is Off
So - the GUI value configs the mW´s... But if Asus 1.0.1.2 defaults to 1496 mW - why can´t you go more than 84mW with Oleg.
PS. Tried the wl txpwr1 -q qdbm_value -o but nothing ever happened. After reboot it was back to 19mW
time for some more #ifdef then I guess
this is a minor bug because of the new wl and how it works, should be an easy fix
Probably the best way is to set the bdm value in the web-config instead of the milliwatts, to make it look more obvious compared to the WL models.
what is maximum LAN to WAN and WAN to LAN throughput on latest Oleg's firmware for N16?
I'm thinking about replacing my WL-500G Deluxe because of low WAN-LAN throughput (25Mbit/s only - 100% CPU usage). My candidates are N16 or Netgear WNDR3700. N16 has about 140 Mbit/s throughput in both directions with stock firware, but WNDR3700 has about 400Mbit/s!!!
qdbm = dbm*4, not more not less, used for fine tuning without fractional part.
according wiki page http://en.wikipedia.org/wiki/DBm, we have
wl driver has limitations 0-1496 mW, or 0-31.75 dBm, so switching to dbm would be wrong, 29 dBm is 794 mW, but 31 is already 1259 mW.Code:26 dBm 400 mW Access point for Wireless networking 20 dBm 100 mW Bluetooth Class 1 radio, 100 m range Typical wireless router transmission power. Maximum output power from unlicensed AM transmitter per U.S. Federal Communications Commission (FCC) rules 15.219.
so, i would allow mW range up to 400 mW (26 bBm) with 50 by default (17 dBm).
current hardware wl adapter defaults will be used, if power value is 0.
any suggestions?
Yes, dBm and qdBm might be confusing both hence they are both based on a logarithmic scale, I was caught up with something when writing that
So it might be a good idea to stick with milliwatts, if it's mentioned on the web-config
If I recall correctly FCC allows a maximum of 1000mW when using 6dB antennas, so I guess it's a good idea to stay under that value by default
And the hardware default is the maximum possible value?
Entered 0 in GUI (Radio Power) and got:
[admin@WL-******** root]$ wl txpwr1
However - still pretty weak signal compared to Asus 1.0.1.2
Maybe this has something to do with it:
[admin@WL-******** root]$ nvram show | grep power
size: 14992 bytes (17776 left)
wl0_radio_power_x=17
wl_radio_power_x=0
Shouldn´t they be the same? In Asus 1.0.1.2 they both are 17 (wl and wl0):
# nvram show | grep power
size: 17662 bytes (15106 left)
wl_radio_power_x=17
# wl txpwr1
