I'm just using the script from: http://wl500g.info/showpost.php?p=47135&postcount=10
I modified it a bit tho, since the start stop utilities are pre-installed with the new firmware
look at: http://wl500g.info/showpost.php?p=203696&postcount=173
Hello everyone,
Will there be a support for unicode characters in file names? Here: http://vip.asus.com/forum/view.aspx?...e=en-us&page=2 is written that the Chinease characters in file names are NOT supported.
Unfortunately, nobody of us know Chinese. Which NLS codepage you are using? Probably, appropriated charset simply turned off in kernel.
updated: We have cp950 turned on, should we change it to cp936? or?
You have to use /proc/diskstats in 2.6 kernel.
even easier
new script:
it should be used likePHP Code:
if /usr/bin/[ $# -ne 1 ]; then
/bin/echo 1>&2 "Usage: $0 <device>"
/bin/echo 1>&2 "example: $0 sda"
exit 1
#Check every 30 seconds for disk io changes
PERIOD=30
#if no changes are found during 5 minutes -> disk spindown
BOUNDARY=300
SCSISTOP=/usr/sbin/scsi-stop
LOGFILE=/tmp/scsi-$1.log
str=`/bin/grep $1 /proc/diskstats`
cooltime=0
stopped=0
while /bin/true; do
/bin/sleep $PERIOD
newstr=`/bin/grep $1 /proc/diskstats`
if /usr/bin/[ "$newstr" = "$str" ]; then
cooltime=$(($cooltime + $PERIOD))
if /usr/bin/[ $cooltime -ge $BOUNDARY -a $stopped -eq 0 ]; then
$SCSISTOP /dev/$1
time=`/bin/date '+%b %e %H:%M:%S'`
/bin/echo "$time: Cooled down..." >> $LOGFILE
stopped=1
if /usr/bin/[ $cooltime -ne 0 ]; then
/bin/echo "$time: Disk first used after $cooltime seconds" >> $LOGFILE
cooltime=0
str=$newstr
stopped=0
done
for each device a new log file will be created./usr/local/sbin/scsi-stop.sh sda &
/usr/local/sbin/scsi-stop.sh sdb &
Yes RSNA-CCMP is WPA2-AES.
I've tried to turn it on today, but it didn't work out that well.
I put my router back to defaults, and after that I got WPA2 working, but as soon as you changed to a different encryption method WPA is used, even when you put it back on WPA2
I tried to reset my router again, but I haven't managed to put WPA2 on again, maybe some sort of bug
WPA is working fine for me for all of the latest builds, but I've another question: When used Bandwidth 20Mhz, then 802.11n SubChannel should be marked as None. But even when saved as None, it shows like Upper or Lower and Upper or Lower should be used only for 40 Mhz. Is that correct?
that's correct
see chapter bandwidth and subchannel: http://code.google.com/p/wl500g/wiki...elessInterface
Following this posts http://wl500g.info/showpost.php?p=193019&postcount=86
today I've re-formated everything (pen with /opt and the 1 Tb hard disk), installed from scratch with r1807 (no usb hubs, no raid partitions) and still no harddisk stability. It stops after couple of reads and writes.
I'm really at a dead end (no backups, no streaming). I'm open for suggestions...
