Page 11 of 19 FirstFirst ... 910111213 ... LastLast
Results 151 to 165 of 283
Thread: alpha rt-n firmware releases
  1. #151
    Seems to be, et driver missing most modern ethtool ioctl's
    Well, I'll try to add support for et driver/
    UPD: et driver exports tcp segmentation, udp large send and scatter-gather offloads...
    maybe too modern ethtool I've used
  2. #152
    Nov 2006
    Currently, et driver supports only commands below:
    ETHTOOL_GSET
    ETHTOOL_SSET
    ETHTOOL_GDRVINFO
    Moreover, it uses an old 2.4 syntax rather than SET_ETHTOOL_OPS() macros, even turned off by default in Broadcom SDK.
    P.S. If you done it, you can sell code back to Broadcom
  3. #153
    Yep, funny.
    So, there're no ways to manipulate offload for now.
  4. #154
    Yep, funny.
    As far as I know GSO should not depend on the ethernet driver. The basic idea is that protocol layers don't handle segments (and memory buffers) separately (it's just SW side improvement). When 10K segments needs to be handled per second (due to 1500 bytes MTU) even that matters a lot (if it can be reduced a bit). I don't know if Broadcom managed to break that.
    The most important question related to the ethernet driver if it has so poor support for various offload features because of the old kernel version or because of the HW's inability. Too bad that there is no documentation for this...
    It's a bit weird that Broadcom produced a driver for a kernel version that pre-dates the announcement of the chip-set by one year and has not released anything new since that. Is it really so?
  5. #155
    Nov 2006
    Quote Originally Posted by ecaddict View Post
    Sorry, I have to read documentation much deeper to agree or disagree with you.
    Unfortunately, Broadcom tries to support single SDK for both 2.4.20 & 2.6.22 kernel versions. Due to very limited features of both obsolete kernels and since Broadcom don't want (as I can understand) to migrate to newer kernels , they simply don't implement future features.
    P.S. I suspect, that due to "crisis" in top managers brains, SDK development was moved to cheaper place with cheaper programmers. As result, quality of code ...
  6. #156
    It seems that /net/core/dev.c has code for this in dev_hard_start_xmit()/dev_queue_xmit(). Having driver support would/could though probably save some copying.
    I wonder if it can be cheaper than Linux community maintaining the drivers' code for free. Of course it would need a bit broader opening towards Linux than just releasing the code/doc. of a few selected drivers.
  7. #157
    The Netherlands - Eindhoven
    that is probably the best investment a company can ever do...
    the only problem is: other people will get to know how a specific technology works, and protecting those technologies... well, they've probably spend a lot of money on that already
    In the end, it's pretty much the same as the movie "the italian job", the mini's (the car) where not sponsored by BMC (the manufacturer), since they didn't understand what a great marketing it would be.
    nowadays a lot of cars get sponsored by the companies that produce them, like in the movie "I robot" with the audi.
    I hope a similar shift will happen in computer land soon, and that other companies will open up their code a bit.
    it's inevitable that linux will grow bigger
  8. #158
    Hey everyone.
    I'm linux noobie and need some help.
    Is it possible to mount a NTFS partition with write support? If it's possible, how? System log tells me that NTFS partition is mounted read-only.
    My harddisk has 4 different partitions: optware (ext3), swap, data (ext3) and data (ntfs).
    The second question is that how can I enable swap? or is it even needed (will the router benefit from it)?
    If anyone is kind enough to help me, I really need clear instructions what to do.
  9. #159
    Thank's for great FW. I think it's a best of all. Before I was using Tomato from Teddy bear, but p2p download was allways too slow. Now, with this FW, DL is allways at full speed. Thank's again and keep on good work.
  10. #160
    Can anyone confirmed, that WPA2 does not working yet. Because I think it is working for me correctly or it is some mistake.
  11. #161
    To come back on the WiFi problem I had...
    it seems that with a few new versions flashed the wifi didn't go down.
    Perhaps it was just a bad flash
    Moreover, I don't want to go back to the old wifi settings since some (embedded) devices won't work with that
    but maybe a bit vivid imaginative explanation: after flashing new firmware the router stops responding a lot of the times and the wifi led starts blinking. this puts the wifi card in a sort of state causing it to crash after a specific time
    I just find it weird that it happens now and then after a flash.
    Anyway, does someone know how to make the harddrives to spin down? hdparm doesn't seem to work and my old scsi script doesn't work for the RT-N (hence it doesn't have any)
  12. #162
    Quote Originally Posted by RdBw View Post
    Are you sure?
    with inssider you can find out if it really broadcasts at WPA2
    http://www.metageek.net/products/inssider
  13. #163
    Nov 2006
    WiFi driver wasn't changed at all, only parameters in r1480...
    Have you try scsi start/stop utilities from project downloads page?
  14. #164
    I know, I'm not saying the driver changed
    I used those utilities on my WL-500W yes, but on my RT-N16 my drives don't show up as scsi drives.
    normally I'd use the utilities in that famous spindown bash script that can be found on the forums, by using this entry /dev/scsi/host0/bus0/target0/lun0/disc
    but I don't even have the directory /dev/scsi
    or should I just use /dev/discs/disca/disc or something?
  15. #165
    2.6 kernel uses /dev/sd[a-z] entry for drives and /dev/sd[a-z][0-9][0-9] dor patritions, and /dev/discs/disca/disc is just a symlink to /dev/sda for now
    Last Post: 14-10-2009, 12:10
    Last Post: 13-07-2008, 02:28
    Last Post: 18-04-2008, 00:34
  4. Visit WL-500g Firmware Releases forum
    By Oleg in forum WL-550gE Firmware Discussion
    Last Post: 18-09-2006, 11:22
    Last Post: 21-10-2004, 15:55
