Try printing other documents. The messages above just indicating that your printer is busy, but this should not cause any problems. Most likely you had these messages with 1.9.2.7-4 too...Originally Posted by hansbr
Oleg,Originally Posted by Oleg
The excel sheet now prints OK, in the syslog however there is still:
May 10 23:26:53 kernel: lp_wait_ready timeout
May 10 23:26:53 kernel: lp_write timeout
should these messages be there?
Tomorrow i will trie some more prints.
Thanks.
Hi, OlegOriginally Posted by Oleg
Good news, this morning
My HP990cxi is functioning again very well in RAW mode and this with the last version of the enhanced driver of HP.
Concerning the bidirectional functionality: the driver shows the possibility to activate the function, but the printer utility cannot use it (no indication of the ink level).
Works for me. Thanks for your help.Originally Posted by Oleg
I have also wondered about that. I have just recently bought my 2nd WL-500g, and it will be upgraded to this new firmware very shortly.Originally Posted by pekr
Will I get better range if i commit this "upgrade" on my WL-500g? I have some problmes with the range one floor down. One floor up is no problem. But that may be because of that the ground floor consists of very much concrete, and my 2nd floor consists of wood... I don't know.
But will I get better range by doing this? And how do I do it? I have already set the TX power to 84 mW.
Thanks. And thanks for a super firmware!!!
Try it. The things are not known in advance.Originally Posted by Muffe
Seems like problems with one unit. Another one works.Originally Posted by pekr
Uploaded updated firmware 1.9.2.7-5a, the changes are:
- Fixed RAW printing bugs, switched to unidirectional transfers by default
- Fixed support for the WPA-PSK in the Client Mode, thanks to miraculix for findings
- Fixed ftp server bug, which prevented files to be uploaded to subdirectories
- CET Timezone update by engy, added Czech Republic
- Increased number of entries on the Bandwidth page up to 32, patch from engy
- Added awk applet, applied mktime patch from engy
- Applied timezones uClibc patch prepared by engy
- Applied tomilius patches adding several new iptables targets
- Updated WL500g Deluxe to use latest ethernet module, removed closed source binaries
Grab your free copy of new firmware, unzip it and flash to your router. As usual, be sure to visit my page if you've not done this yet.
ths ftp server with subdirectories pb ...........still not working ....
maybe other things have to be made after the firmware upgrade ??!!!
thanks a lot
please do not shorten words, 'PB' is not a known abbrevationOriginally Posted by biglio
I suppose you mean problem (!?)
yes i meant problem ......excuse me .....
i am french and this abrevation in FRANCE is well known ...sorry !!!!
but the problem is stiil there so .... is strange...but it s real
Has anyone else tried building the 1.9.2.7-5a release from the sources?. I tried serveral times but the same error apparently in patching a Makefile. I have successfully compiled the 1.9.2.7-4 sources in the past. I do the following...
tar -C . -xzf ./GPL_1927.tar.gz
tar -C ./broadcom/src -xjf ./wl500g-1.9.2.7-5a.tar.bz2
cd broadcom/src
cd *-5a
make uClibc
make kernel
make
Here is where the trouble is I get the following message
tar -C /home/d/wl500g1927-5/broadcom/src/router -cf - libcrypto | tar -C /home/d/wl500g1927-5/broadcom/src/gateway -xf -
[ ! -f libcrypto.diff ] || patch -d /home/d/wl500g1927-5/broadcom/src/gateway -p1 --no-backup-if-mismatch < libcrypto.diff
patching file libcrypto/Makefile
[ -f /home/d/wl500g1927-5/broadcom/src/gateway/Makefile ] || cp /home/dwl500g1927-5/broadcom/src/router/Makefile /home/d/wl500g1927-5/broadcom/src/gateway && patch -d /home/dwl500g1927-5/broadcom/src/gateway -p1 < Makefile.diff
patching file Makefile
[ -f /home/d/wl500g1927-5/broadcom/src/gateway/Makefiles5.mk ] || cp /home/d/l500g1927-5/broadcom/src/router/Makefiles5.* /home/d/wl500g1927-5/broadcom/src/gateway && patch -d /home/dwl500g1927-5/broadcom/src/gateway -p1 < Makefiles5.diff
/bin/sh: Makefiles5.diff: No such file or directory
make: *** [custom] Error 1
I'm not sure if I have the new step to make uClibc in the right order (it ssems like the right place). I can't find the file Makefiles5.diff anywhere. The error is in Makefile in broadcom/src/wl500g-1.9.2.7-5a.
Sorry to heap another complaint after the printer storm.
remove this line, it's no longer needed.
I would like to access my webcam picture (not the stream) (http://my.routers.ip.address:7776/display.jpg) from the internet, without having to use the password. I have STF but I could only find something with another (old) firmware. Is this possible with the 1.9.2.7-5a firmware, width og widthout modifications?
I will use the picture in my website, accessible for everyone...
Thanks. And thanks for a great forum and a great firmware.
Newer firmwares includes mostly everything, that was included before, so it should work.Originally Posted by Muffe
