Page 5 of 13 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 190
Thread: Firmware v1.9.2.7 CR5, updated: v1.9.2.7 CR5a [Oleg]
  1. #61
    Problem with CR5 and HP Printer: fix for parallell interface is not working
    do you've timeouts in the system log?
    First of all, you find as annex the syslog made with CR4 from boot up to time after a successful print.
    In order to document the problem I have installed again CR5. You find as further annexes:
    1) Syslog with CR5 without fix: from boot up to time after print of 2 documents (both documents unsuccessful)
    2) Syslog with CR5 with fix : from boot up to time after print of 4 documents:
    first doc: short doc printed with basic driver: successful
    second doc: XP printer test page with basic driver: partly unsuccessful
    third doc: short doc with HP driver: unsuccessful
    fourth doc: XP printer test page with HP driver: unsuccessful
    Would other infos be useful for you before i go back again to CR4 installation?
    Ok, everyone with RAW print problems are invited to test this firmware: http://wl500g.dyndns.org/WL500g-1.9.2.7-5a-pre1.trx and let me know if it starts working and other printing problems you probably have with RAW printing.
  3. #63
    Aalborg, Denmark
    Sorry, but WL500g-1.9.2.7-5a-pre1.trx do not work for my, but different than WL500g-1.9.2.7-5.trx. Look like some missing/corrupted/extra chars are sent to the printer. I just do the "Print Test Page" in Windows XP, so I can't provide further details, sorry.
  4. #64
    FIB, it should work for you, as I've removed -b. Please try with trick again (should not help if you've flashed right firmware).
  5. #65
    Problem with CR5 and HP Printer: CR5a-pre1 not OK in RAW modus; OK in LPR
    Hello Oleg, Thanks for your efforts to solve our printer problems.
    I have installed the 5a-pre1 version.
    In my case I register unfortunately no progress. In raw modus the printer does not print anything more correctly. Same situation with the basic driver or with the HP driver.
    As I need to use the print server, I tried to switch to the LPR modus. The result is positive. The printer is working correctly. (I don't know if it was also the case with the original CR5 version; I did not test it earlier). So at this time I will stay with your last version and print with the LPR modus. In waiting and hope that a solution is once available for the RAW modus. I will also inform you if the other functions of 5a-pre1 are workink correctly.
  6. #66
    Apr 2005
    Denmark
    still printer problems
    Hi Oleg
    I try the firmware, and the printer (hp890), print all the text, and a lot of other characters, my canon printer (Pixma4000), connected to the usb port, can't print at all.
    With the firmware 1.9.2.7-5, the Canon printer, prints one good print, than I have to reboot, to get the printer work again.
    If I after a reboot print one one the HP printer, then I can't print one the canon after this
    Sorry for my english.
    /Emand
  7. #67
    Aalborg, Denmark
    The trick:
    killall p910nd
    p910nd -f /dev/usb/lp0 0
    do not do any difference on (my ) WL500g-1.9.2.7-5a-pre1.trx.
  8. #68
    I need a system logs from unsuccessful printings. Please post them.
  9. #69
    Aalborg, Denmark
    From WL500g-1.9.2.7-5a-pre1.trx no trick.
    Hi Oleg,
    In the attachment the needed syslog (from boot time up to unsuccessful printing in RAW.
  11. #71
    Apr 2005
    Denmark
    I have maked a save in the syslog windows in the web interface, im not sure that this is log file you mean.
    (5a-Pre1)
    /Emand
  12. #72
    May 2005
    Geldrop
    Oleg,
    I put your new firmware in the wl-500g. (5a-pre1)
    Printing to my parallel port got worse, printing the same exel file as yesterday, gives a lot of corrupted text/pages.
    thanks for your effort.
    Hans
    Quote Originally Posted by kdudl
    Hi Oleg,
    Sorry, attachment was missing...
    Guys, yet another attempt. Fixed a stupid error in -pre1, do not use it anymore. Try this one and let me know if you are happy now.
  15. #75
    Apr 2005
    Denmark
    The problem seems to be solved
    It seems that both of my printers are working all right now.
    Thanks
    /Emand
  1. Firmware v1.9.2.7 CR6, updated to CR6a ... now CR6b [Oleg]
    Last Post: 09-02-2006, 09:19
  2. Replies: 8
    Last Post: 17-05-2005, 10:21
  3. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 10:01
  4. Firmware v1.7.5.6 CR3 [Oleg]
    Last Post: 28-07-2004, 21:11
  5. Firmware v1.7.5.6 CR2.1 [Oleg]
    Last Post: 03-05-2004, 11:13
