Page 2 of 13 FirstFirst 123412 ... LastLast
Results 16 to 30 of 190
Thread: Firmware v1.9.2.7 CR5, updated: v1.9.2.7 CR5a [Oleg]
    I found something interest...
    when I upgrade to this new version firmware..
    I thought I should reset all data configration...
    But after I push the buttom after 5 seconds then turn off my AP
    When I turn on it again...the Page has not asked me to set all new data
    and the data also there...just like I have not upgrade it...
    So?...what's problem with the reset buttom?
    Mar 2005
    Hi Oleg,
    just a great work! Thanks from Germany
    rolano
    ASUS WL-HDD, DBOX2-SAT
    Jul 2004
    near Lyon @ France
    not so easy to compile
    is my build system broken or are there strange behaviour in the new firmware source ?
    1) I noticed that lzma.zip contains a dos exe (lzma.exe). Should my unzip be capable handling it ? Because I find it not to be
    2) I did not remember previous firmware to depends on ncurses for building. In this one, 'make oldconfig' called by main Makefile at some stage do some stuff that finally broke, asking for ncurses devel + libs.
    3) I have some trouble at the wl.o extracting stage. wl.o file created appears to be 0 bytes while the original .gz one has been extracted at its original place. *strange*
    Any idea ?
    Quote Originally Posted by Jean-Fabrice
    yes, unzip handles this nicely.
    this is from the begining - ncurses are needed for make menuconfig, which is get called for both firmware and kernel.
    works fine for me too. Your gunzip does not understand -c option as seems, does it really old?
    Quote Originally Posted by emilyaoo
    you should release button, then LED is blinking, not then it's off.
    Quote Originally Posted by tonia
    will this firmware work with 2 bridged 500g in WDS using WPA?
    It should work, read 1.9.2.7 CR4 thread if it does not.
    Will you release a fix for the: "et1: rx stuck suspected"? Or can I fix it my self? I get one every minute and it's clogging up my syslog..
    B.
    Quote Originally Posted by barsju
    B.
    I've re-uploaded files to http://oleg.wl500g.info/1.9.2.7-5/
    Antiloop, please update your mirror.
    Unfortunately, It does not work. (in my case and with: 2 * WL-500g in AP mode, WDS and WPA-PSK / AES).
    Here's what i did:
    I had a working WDS setup with the ASUS 1.9.4.0 firmware and flashed both routers with 1.9.2.7-CR5 firmware, leaving the settings unchanged. After reboot; WDS NOt working.
    Then flashed both routers back with 1.9.4.0, again leaving the settings unchanged. WDS is working now...
    Sep 2004
    hi,
    nfsserver with rsize/wsize=32768 is pretty fast, but after enable the NFS-Server, the log seems to stops after:
    Jan  1 01:00:02 kernel: PDC20265: IDE controller on PCI bus 01 dev 08
    Jan  1 01:00:02 kernel: PCI: Enabling device 01:01.0 (0004 -> 0007)
    Jan  1 01:00:02 kernel: PDC20265: chipset revision 2
    and the 'clear', 'save', 'refresh' button are no longer available...also after reset to factory default. If I disable NFS-Server, the log continuus and the buttons get visible again.
    cu,
    peter
    PS:after enable/disable/enable the NFS-Server the buttons are back and the log works...I dont know why.
    Nov 2003
    Eindhoven
    files updated
    Changes:
    • Added chat ppp program
    What is this and where can I find it?
    Nov 2003
    Eindhoven
    Quote Originally Posted by dejay
    if you don't know what it is, you probably don't need and don't miss it
    it's a chat program for PPP
    Aalborg, Denmark
    Problems with USB-printer
    Hi Guys,
    I got trouble with my USB printer. It just print incomplete jobs. No problems on WL500g-1.9.2.7-4.trx.
    From the System Log:
    Jan 1 01:00:11 kernel: printer.c: usblp0 Device ID string [117/max 1552]='MFG:Canon;CMD:BJL,BJRaster3,BSCCe;SOJ:TXT01;MDL: i560;CLS:PRINTER;DES:Canon i560;VER:1.06;STA:10;POS:000000FFFFFFFF;'
    Jan 1 01:00:11 kernel: printer.c: Parsing USBLPID...
    May 8 10:38:13 kernel: printer.c: usblp0 Device ID string [117/max 1552]='MFG:Canon;CMD:BJL,BJRaster3,BSCCe;SOJ:TXT01;MDL: i560;CLS:PRINTER;DES:Canon i560;VER:1.06;STA:10;POS:000000FFFFFFFF;'
    May 8 10:38:13 kernel: printer.c: Parsing USBLPID...
    May 8 10:38:38 p9100d[69]: Connection from 192.168.1.72 port 1271 accepted
    Btw. Samba is OK now.
    Aug 2004
    Hi
    I had two strange things:
    • Dieing PPPd ???
      (Edit: Happened only once, but strange)
      Jan  1 01:00:21 pppd[97]: Modem hangup
      Jan  1 01:00:21 pppd[97]: Connection terminated.
      Jan  1 01:00:21 pppd[97]: Connect time 0.1 minutes.
      Jan  1 01:00:21 pppd[97]: Sent 808 bytes, received 254 bytes.
      Jan  1 01:00:21 kernel: Unable to handle kernel paging request at virtual address 000000e8, epc == 800d1b18, ra == 800d1af0
      Jan  1 01:00:21 kernel: Oops in fault.c::do_page_fault, line 192:
      Jan  1 01:00:21 kernel: $0 : 00000000 802048c4 00000001 00000039 807b4790 00000000 00000000 00000008
      Jan  1 01:00:21 kernel: $8 : 00000039 00000071 00000010 7465398e 00005000 00000000 00004000 00000000
      Jan  1 01:00:21 kernel: $16: 802147e8 80983180 807b4760 00000000 806ade98 7fff79c8 00000000 7fff7a80
      Jan  1 01:00:21 kernel: $24: 00000010 2abd8120                   806ac000 806ade58 7fff7b2a 800d1af0
      Jan  1 01:00:21 kernel: Hi : 00000000
      Jan  1 01:00:21 kernel: Lo : 0000000e
      Jan  1 01:00:21 kernel: epc  : 800d1b18    Not tainted
      Jan  1 01:00:21 kernel: Status: 1000fc03
      Jan  1 01:00:21 kernel: Cause : 00000008
      Jan  1 01:00:21 kernel: Process pppd (pid: 97, stackpage=806ac000)
      Jan  1 01:00:21 kernel: Stack:    0083869b 00000042 806ac000 80961840 7fff7e18 8029eaf8 0000001e
      Jan  1 01:00:21 kernel:  00000003 7fff7ee4 7fff79c8 800ead94 800ead50 80bf6e90 800c58e0 800c5638
      Jan  1 01:00:21 kernel:  00030002 00000018 00000000 411a9000 7465398e 07003168 8c282ac5 60002ac9
      Jan  1 01:00:21 kernel:  800c1001 fffffff0 80ef9b80 806551e0 8027d2e0 8071b220 80037a44 809dec60
      Jan  1 01:00:21 kernel:  80042c58 802af000 809dec60 806551e0 809f16e0 00000000 00000003 80035ebc
      Jan  1 01:00:21 kernel:  80035ea8 ...
      Jan  1 01:00:21 kernel: Call Trace:   [<800ead94>] [<800ead50>] [<800c58e0>] [<800c5638>] [<800c1001>]
      Jan  1 01:00:21 kernel:  [<80037a44>] [<80042c58>] [<80035ebc>] [<80035ea8>] [<800085a4>]
      Jan  1 01:00:21 kernel: Code: 00000000  8e450024  24020001 <c0a400e8> 00821823  e0a300e8  1060fffc  00821823  0000000f
      Jan  1 01:00:21 pppd[135]: Plugin rp-pppoe.so loaded.
      Jan  1 01:00:21 pppd[135]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.2
      Jan  1 01:00:21 pppd[136]: pppd 2.4.2 started by admin, uid 0
    • Terracam Pro (OV518) not Working, green Picture
      May  8 12:41:14 USB webcam: webcam capture no frame
      (Repeating)
    - Can you make LPR, Waveserver, Jetdirekt printing jobs and maybe infosvr disable over web interface ?
    - The USB RS232 Modules are nice
    Greets
  1. Firmware v1.9.2.7 CR6, updated to CR6a ... now CR6b [Oleg]
    Last Post: 09-02-2006, 09:19
  2. Replies: 8
    Last Post: 17-05-2005, 10:21
  3. Firmware v1.8.1.7 CR2 [Oleg] - updated ( CR2a )
    Last Post: 08-12-2004, 10:01
  4. Firmware v1.7.5.6 CR3 [Oleg]
    Last Post: 28-07-2004, 21:11
  5. Firmware v1.7.5.6 CR2.1 [Oleg]
    Last Post: 03-05-2004, 11:13
