Originally Posted by
Miata
Thx for your reply.
I'm running the original firmware and logging does not even show that somebody logged in
It seems Oleg did a better job.
no logging at all?
you could also try to do that command via the web interface of the original firmware: http://ip-of-your-router/Main_AdmStatus_Content.asp
it gives you a console where you can execute the code
when someone is logged in you will see something like:
tcp 469 0 192.168.1.1:21 192.168.1.30:53489 ESTABLISHED
everywhere it says something like "192.168.1.1:21" it's an ftp connection (port 21)
