Results 1 to 2 of 2
Thread: Using jffs2 with usb stick
    Apr 2009
    Sofia,Bulgaria
    Hello,
    I'm using WL500gp-1.9.2.7-d-r1000 firmware.
    using the modules-1.9.2.7-d-r1000.tgz I managed to enable jffs2
    cd /opt
    tar -xf modules-1.9.2.7-d-r1000.tgz -z
    and in /opt/lib I have /modules/2.4.20/ subfolder
    After this with modprobe I enabled jffs2 (crc32 is required)
    now "cat /proc/filesystems" shows jffs2
    nodev   rootfs
    nodev   bdev
    nodev   proc
    nodev   sockfs
    nodev   tmpfs
    nodev   shm
    nodev   pipefs
    nodev   eventpollfs
            ext3
    nodev   ramfs
            msdos
            vfat
    nodev   devfs
            ntfs
            squashfs
    nodev   usbdevfs
    nodev   usbfs
            jffs2
    I don't know now how to format the usb stick (2gb).
    I was not able to find any pakage from oleg repository, which brings jffs2 formattiong utility - mkfs.jffs2. I can not find also "mtd tools" package.
    Can you please help me! How to format the USB stich and start using it ?
    Thanks in advance !
    The Netherlands - Eindhoven
    you can format it in a linux distribution on your pc with gnome partition manager, or you can download the gparted live cd: http://gparted.sourceforge.net/livecd.php
    probably the easiest way
    Last Post: 14-03-2012, 15:28
  2. cannot partition dane-elec usb stick
    By vleutmans in forum WL-500gP Q&A
    Last Post: 01-10-2009, 13:34
  3. Проблема: USB 1.1 устройства через USB 2.0 хаб
    By Rambalac in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 15-09-2009, 12:00
  4. USB stick super heat + locks fileserfer/web interface
    By flexusz28 in forum WL-500w Q&A
    Last Post: 06-09-2009, 23:52
