Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
Thread: Firmware v1.9.4.0 BETA
    Just to confirm the reboot problem - both my units occasionally auto-reboots 2-4 times a day.
    Quote Originally Posted by tonia
    My 500g has not the auto reboot problem.
    Last week the router crashed once, after a reset it works again.
    Running 5 days stable without disconnects, reboots now
    Save setting doesn't work for me in 1.9.4.0 Beta. Saved CFG file is empty - zero size.
    Jun 2004
    Germany - Near Rüsselsheim
    Hi Guys,
    Just to confirm the reboot problem - my WL500g occasionally auto-reboots 2-4 times a day.
    I did flash back to oleg last version. This one works fine for me.
    cu
    Dirk
  5. Settings CFG
    Hello
    I hafe the same problem with zero size of Settings.cfg it is 0 Byte too at me.
    and another what i see in the log
    Jan 1 01:00:22 pppd[58]: Warning - secret file /tmp/ppp/pap-secrets has world and/or group access
    Jan 1 01:00:22 pppd[58]: Warning - secret file /tmp/ppp/chap-secrets has world and/or group access
    Twisterchen
    Hey guys!
    After updating the firmware to 1.9.4.0 I had the same problems like chris4335 and twisterchen. I think the problem is caused by the dsl-modem. I have a very old Teledat 300 LAN (T-Online). After downgrading the firmware back to 1.9.2.7 it worked again.
    Greets,
    Mr. Orange
    Hey guys, why can't i downgrade anymore?
    If i flash a older firmware than 1.9.4.0, the device always resets, while booting an don't comes up anymore. Although with the openwrt flashfiles, i get this error.
    What's the reason and what can i do against that?
    I already flashed the nvram-reset flash, but this didn't work for me. :-(
    thank you
    DaemonB
    Apr 2004
    Netherlands
    Have you tried pressing the reset button for like 10 seconds while powering on?
    If i do that, the router is going into the failover Mode (right expression?), so the power LED is blinking all the time.
    Or didn't I hold the resetbutton long enough?
    thank you
    DaemonB
    Hi guys,
    the only firmware i can run is the experimental openwrt, but that's ok.
    thank you
    DaemonB
    Jun 2004
    Portugal
    1.9.4.0 beta problem - stops for about 5 to 10 mins
    Hi.
    I just tried this beta firmware, and it helped on P2P connections.
    But I found another problem. At least once a day, specially after long use of P2P connections, it decides to stop for about 5 to 10mins. Most of the times it resumes after that, but sometimes it doesn't. It does not disconnect, I am able to reach router and see Status showing it is connected, WAN led still on and blinking with activity. Just doesn't serve requests, any protocol.
    I have a friend that has a WL-500g and has upgraded to same firmware. We both did full resets before and after flashing and introduced manually all settings. We both experience same problem.
    Any ideas? Thanks in advance.
    P.S.: I'm going to try and set the WAN port negotiation to 10Mbps full duplex, and see if it makes any diference. Will update with info later.
  12. this seems to be an uart1 problem
    i upgraded my modem to an uart2 one and everything is fine now
    Quote Originally Posted by fastfox
    How did you do that?
  1. Firmware v1.9.3.9 BETA
    By Antiloop in forum WL-530g Firmware Releases
    Last Post: 04-06-2006, 13:38
  2. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-300g Firmware Releases
    Last Post: 18-11-2005, 09:49
  3. Firmware v1.9.3.6 BETA
    Last Post: 27-04-2005, 07:54
  4. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-500gx Firmware Releases
    Last Post: 20-03-2005, 02:40
  5. Firmware v1.7.5.7 BETA
    Last Post: 12-05-2004, 23:03
